1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: caget command holds for more than 10 seconds
To: "Dirk Zimoch" <[email protected]>, "lailongwei" <[email protected]>
Date: Tue, 31 May 2011 10:08:09 -0500
Hi Dirk,
I think there are 3 problems:
1) I think lailongwei is running caget 4 times to get 4 PVs.  Perhaps he
is not aware that he can get 4 PVs running caget only once:
corvette:> /usr/local/epics/base-3.14.12.1/bin/linux-x86/caget 13IDA:m1
13IDA:m2 13IDA:m3 13IDA:m4
13IDA:m1                       -0.25007
13IDA:m2                       1.19993
13IDA:m3                       -0.649928
13IDA:m4                       0.49989
2) Your point that even those values are not truly sampled at the same
time.
3) The problem he is probably really complaining about, which is that
caget it taking 10 seconds to complete, whereas when things are working
well it should take less than 50ms to complete.  This means that there
is something seriously wrong with caget, and he is not the first one to
report this.  I have seen it take up to 5 seconds to complete from some
hosts to some IOCs, as has Jay Steele.
-----Original Message-----
[mailto:[email protected]] On Behalf Of Dirk Zimoch
Sent: Tuesday, May 31, 2011 7:14 AM
To: lailongwei
Cc: tech-talk
Subject: Re: caget command holds for more than 10 seconds
lailongwei wrote:
> hi,
>   when I use caget A, though the data has been gotten, it holds for
> about ten sends untill the command exit.
> This cause problem when I need to caget four PVs, whose sampling at
the
> same time is very important. How can I solve it.
> Thanks!
> 2011-05-31
> lailongwei
One could argue that strictly speaking sampling over the network is
"wrong". TCP and thus CA does not support any real-time behavior. So the
best way to solve it is to sample all four PVs on the same real-time
IOC. This probably does not help when the PVs are not physically
connected to the same IOC. For the future SwissFEL project, we (meaning
Babak) took great effort to implement this kind of synchronous data
acquisition across multiple IOCs. Our implementation strongly depends on
our timing system to synchronize PVs on multiple IOCs. This is nothing
you can quickly do with a 'caget a; cage b; caget c; caget d;'
Dirk
caget command holds for more than 10 seconds lailongwei
Re: caget command holds for more than 10 seconds Dirk Zimoch
Prev: Re: caget command holds for more than 10 seconds Dirk Zimoch
Next: RE: caget command holds for more than 10 seconds Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: caget command holds for more than 10 seconds Hinko Kocevar
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
