1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: caget command holds for more than 10 seconds
To: tech-talk <[email protected]>
Date: Tue, 31 May 2011 12:07:02 +0200
10 seconds is the default timeout for channels that are not found.
Can you please show the command line you are using and its output? It would also be useful to know which system you are running caget on, and which version of EPICS you are using.
~Ralph
On 31.05.2011 04:17 lailongwei wrote:
hi,
  when I use caget A, though the data has been gotten, it holds for about ten sends untill the command exit.
This cause problem when I need to caget four PVs, whose sampling at the same time is very important. How can I solve it.
Thanks!
2011-05-31
lailongwei
RE: caget command holds for more than 10 seconds Mark Rivers
caget command holds for more than 10 seconds lailongwei
Prev: caget command holds for more than 10 seconds lailongwei
Next: RE: caget command holds for more than 10 seconds Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
