1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Problems with executing caExample for 3.14.12.1
To: "'Mark Rivers'" <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 27 May 2011 09:23:31 -0700
Done.  Mark, you were right in that I was did not have an CAS up and running while I was attempting to invoke caExample.   All is working now.
Thanks for the help/assistance.
Florencio
Sent: Wednesday, May 25, 2011 5:24 PM
To: Cid, Florencio A; [email protected]
To get rid of the carepeater error messages just put the path to epics-base/bin/cygwin-x86 in your PATH environment variable.
The timeout error is another problem.  Are you running an IOC that contains the PV ai1?
From: [email protected] [mailto:[email protected]] On Behalf Of Cid, Florencio A
Sent: Wednesday, May 25, 2011 6:12 PM
To: '[email protected]'
Subject: Problems with executing caExample for 3.14.12.1
Hi All,
I am new to EPICS and trying run thru the example applications.   Specifically, I am encountering the following error  when attemping to Channel Access Host Example per the procedures in Section 2.3 of the EPICS Application Developer’s Guide.
 [ui495a@macpro-fcid ...c/mytop]$ c:/mytop/bin/cygwin-x86/caExample ai1
**** The executable "caRepeater" couldn't be located
**** because of errno = "No such file or directory".
**** You may need to modify your PATH environment variable.
**** Unable to start "CA Repeater" process.
CA.Client.Exception...............................................
    Warning: "User specified timeout on IO operation expired"
    Context: "ca_pend_io failure"
    Source File: ../caExample.c line 20
    Current Time: Wed May 25 2011 16:53:09.202188000
    Warning: "Virtual circuit disconnect"
    Context: "ca_get failure"
    Source File: ../caExample.c line 21
    Current Time: Wed May 25 2011 16:53:09.234188000
ai1 0.000000    Context: "
"a_pend_io failure
    Source File: ../caExample.c line 22
    Current Time: Wed May 25 2011 16:53:14.234188000
    Current Time: Wed May 25 2011 16:54:49.445573000
    Current Time: Wed May 25 2011 16:54:49.446573000
ca_pend_io failure"
    Current Time: Wed May 25 2011 16:54:54.446573000
I’ve successfully built EPICS base (3.14.12.1) via EPICS_HOST_ARCH = cgwin-x86.    The steps do not mention anything about a caRepeater.   Looks like I’m missing something really subtle (as an EPICS “new-bie”).  Any help/assistance/info will be greatly appreciated.
Thanks in advance,
Florencio Cid
Problems with executing caExample for 3.14.12.1 Cid, Florencio A
RE: Problems with executing caExample for 3.14.12.1 Mark Rivers
Prev: RE: epicsTypes.h/inttypes.h question Jeff Hill
Next: Steve Lewis Bruce Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: Problems with executing caExample for 3.14.12.1 Mark Rivers
Next: record ring buffer flushing Hinko Kocevar
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
