1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Windows XP Cygwin difficulties for building EPICS base
To: "'Andrew Johnson'" <[email protected]>
Date: Tue, 24 May 2011 13:50:37 -0700
Success!!  I've been able to successfully build the EPICS base (without the cap5
options)... Thank you Bejamin.
Will now start to develop some IOCs and CASs.  Hopefully no issues with the build.
But will re-install a clean cygwin and perl (eventually)..  Thank you Andrew.
Thanks again for the help/assistance.
Florencio
-----Original Message-----
Sent: Tuesday, May 24, 2011 1:34 PM
To: Cid, Florencio A
Cc: [email protected]
Subject: Re: Windows XP Cygwin difficulties for building EPICS base
Hi Florencio,
On 2011-05-24 Cid, Florencio A wrote:
> Thanks for the info/assistance.  OK...  I understand.  How do I disable the
>  optional building of the perl CA interface?
Follow Benjamin's suggestion of commenting out the "DIRS += cap5" line in the
src/Makefile
> Another question, for some
> reason the perl interpretor in my cygwin install is not working correctly.
> Should I try to uninstall and re-install cygwin perl module?
Perl is essential for building EPICS software, but it doesn't need the other
executables such as podchecker or pod2html that are used in src/cap5.  If you
don't have any other issues with the build then your Perl installation is
probably working sufficiently, although eventually you might want to try re-
installing it.
- Andrew
Optimization is the process of taking something that works and
replacing it with something that almost works, but costs less.
-- Roger Needham
Re: Windows XP Cygwin difficulties for building EPICS base Andrew Johnson
RE: Windows XP Cygwin difficulties for building EPICS base Cid, Florencio A
Prev: Re: Windows XP Cygwin difficulties for building EPICS base Andrew Johnson
Next: Re: Suggestion for IOC log server Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Device Support for Nemic Lambda Power Supplies Anthony Andrews
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
