On 24.05.2011 16:33 Williams Jr., Ernest L. wrote:
Hi
Is this the same as procServ
One layer above.
procServ allows telnet access to soft IOCs - it is the "soft" one channel version of a console server (aka Moxa box or equivalent).
Conserver [1] is a daemon that connects to console connections - provided by procServ, Moxa boxes, serial lines, etc.
The conserver daemon basically keeps the connection to all the consoles up and does the logging. It also provides a TCP based service that allows
users to connect to consoles by means of a client program called console. The conserver daemon provides authentication for these user connections,
makes sure only one gets write access, etc.
The user calls "console <iocname>", which connects to the conserver daemon.
The conserver daemon authenticates the user, and connects the user to the console connection of the specified IOC.
That IOC can be a soft IOC under procServ, a VME IOC connected to a terminal server, anything serial connected somehow to something. The connection
details are part of the conserver daemon configuration, the user only needs the IOC name.
Ralph
[1] http://www.conserver.com/
- RE: Suggestion for IOC log server Davidsaver, Michael
- Device Support for Nemic Lambda Power Supplies Anthony Andrews
- Re: Device Support for Nemic Lambda Power Supplies Eric Norum
- Suggestion for IOC log server Abadie Lana
- Re: Suggestion for IOC log server Ralph Lange
- Re: Suggestion for IOC log server Williams Jr., Ernest L.
Re: Windows XP Cygwin difficulties for building EPICS base Andrew Johnson
<2011>
<2011>
