On Monday, May 23, 2011, Dirk Zimoch wrote:
> > [...] One exception frequently cited is when
> > starting an IOC its maybe ok, but if this occurs in common library code
> > then it's probably going to be used inappropriately in other
> > situations, and surely eventually we will need to upgrade allowing
> > online add and delete of records and then it's less clear when iocInit
> > starts and ends?
> This show why C++ exceptions are better than the good old C abort().
Certainly. If only one didn't have to buy all the other C++ trash together
with the very few features that are actually improvements over C...
> If
> creation of a new record fails because of insufficient memory, an
> exception can be thrown. During run-time it should be caught and an
> error should be reported to the user that the record can't be added to
> the system. During initialization, it may be acceptable not to catch the
> exception which will in the end call abort(). Thus the application
> developer and not the support library developer decides if the
> application (here the ioc) must die or not.
> By the way, if creation of a record fails because of a typo in a
> template file, the ioc happily continues starting up, but with one or
> many records missing -- even though this *is* a programming error, not a
> run-time problem.
Cheers
Ben
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführer: Prof. Dr. Anke Rita Kaysser-Pyzalla, Prof. Dr. Dr. h.c. Wolfgang Eberhardt, Dr. Ulrich Breuer
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
- caGateway crashes / use of *MustSucceed functions Dirk Zimoch
- RE: caGateway crashes / use of *MustSucceed functions Jeff Hill
- Re: caGateway crashes / use of *MustSucceed functions Dirk Zimoch
vxWorks network problems Dirk Zimoch
<2011>
<2011>
