Hi Janet,
Actually, I was using
SHARED_LIBRARIES=YES and STATIC_BUILD=NO.
I saw your message answering to Kaz's question and double-checked
before I asked. So I thought it would not be the problem.
But after I run into sscan problem, (and asyn, too), I found an old
thread where Mark Rivers suggested using
SHARED_LIBRARIES=NO and STATIC_BUILD=YES
And Tim Mooney just pointed that problem out a moment ago.
So I went back change the options and did the Base 3.14.12.1
installation again. Now it works! I checked again, and sure, for 3.14.11,
I used the former option set and it worked. Apparently it is not for
3.14.12. I guess something is changed between the two version?
Now I am recompiling the synApp and hope things work better there,
too.
Thanks all for the help!
Zhan
Zhan Zhang, Ph. D.
Argonne National Laboratory
X-ray Science Division, 438-D005
9700 S. Cass Ave.
Argonne, IL 60439
Tel : 630-252-0863
Email: [email protected]
-----Original Message-----
Sent: Friday, May 20, 2011 3:30 PM
To: Zhan Zhang
Cc: [email protected]
Subject: Re: Problem installing EPICS Base 3.14.12.1 on Cygwin/Win XP
(32bit)
This can happen if you have both SHARED_LIBRARIES=YES and
STATIC_BUILD=YES?
From the CONFIG_SITE file:
# NOTE WIN32: YES results in a DLL. Valid settings are
# SHARED_LIBRARIES=YES and STATIC_BUILD=NO
# SHARED_LIBRARIES=NO and STATIC_BUILD=YES
Janet
Zhan Zhang wrote:
> Hi EPICS folks,
> When trying to compile base 3.14.12.1 on my Cygwin installation on
> WinXp (32 bit), I got the error message about parse.c (attached at the
end).
> It is fairly similar to what Kaz described late last year in this thread--
> http://www.aps.anl.gov/epics/tech-talk/2010/msg02120.php
> However, in my case, I am not compiling for win32-x86 but for
> cygwin-x86. There should be no '\\' problem for the paths. I also
checked
> the file permission and my antelope.exe file is executable, both in
> Windows-native and Cygwin environment. Similar to Kaz's experience, I had
> no problem compiling 3.14.11. I am using Gnumake 3.8.1 coming with my
> Cygwin installation, though I am not sure hold old my cygwin is. I kind
of
> remember that compiling 3.14.8.2 for win32-x86, I had to use 3.8.0 to deal
> with the '\\' problem. But I just don't know how to get make-3.8.0 to
work
> with 3.14.12, because in RULES.TARGET, there is comments about 3.8.1 and
> later only. I could not get pass that with 3.8.0. For now, I will stick
> with 3.14.11. But I just wonder what could cause my problem.
> Thanks!
> Here goes the error message (between ****)--
> $ make
> make -C ./configure install
> make[1]: Entering directory `/usr/local/base-3.14.12.1/configure'
> make -C O.cygwin-x86 -f ../Makefile TOP=../.. T_A=cygwin-x86 install
> make[2]: Entering directory
> `/usr/local/base-3.14.12.1/configure/O.cygwin-x86'
> make[2]: Nothing to be done for `install'.
> make[2]: Leaving directory
> make[1]: Leaving directory `/usr/local/base-3.14.12.1/configure'
> make -C ./src install
> make[1]: Entering directory `/usr/local/base-3.14.12.1/src'
> make -C ./tools install
> make[2]: Entering directory `/usr/local/base-3.14.12.1/src/tools'
> make -C O.cygwin-x86 -f ../Makefile TOP=../../.. T_A=cygwin-x86 install
> make[3]: Entering directory
> `/usr/local/base-3.14.12.1/src/tools/O.cygwin-x86'
> make[3]: Nothing to be done for `install'.
> make[3]: Leaving directory
> make[2]: Leaving directory `/usr/local/base-3.14.12.1/src/tools'
> make -C ./makeBaseApp install
> make[2]: Entering directory `/usr/local/base-3.14.12.1/src/makeBaseApp'
> `/usr/local/base-3.14.12.1/src/makeBaseApp/O.cygwin-x86'
> make[2]: Leaving directory `/usr/local/base-3.14.12.1/src/makeBaseApp'
> make -C ./makeBaseExt install
> make[2]: Entering directory `/usr/local/base-3.14.12.1/src/makeBaseExt'
> `/usr/local/base-3.14.12.1/src/makeBaseExt/O.cygwin-x86'
> make[2]: Leaving directory `/usr/local/base-3.14.12.1/src/makeBaseExt'
> make -C ./libCom install
> make[2]: Entering directory `/usr/local/base-3.14.12.1/src/libCom'
> `/usr/local/base-3.14.12.1/src/libCom/O.cygwin-x86'
> make[2]: Leaving directory `/usr/local/base-3.14.12.1/src/libCom'
> make -C ./toolsComm install
> make[2]: Entering directory `/usr/local/base-3.14.12.1/src/toolsComm'
> make -C ./antelope install
> `/usr/local/base-3.14.12.1/src/toolsComm/antelope'
> make -C O.cygwin-x86 -f ../Makefile TOP=../../../.. T_A=cygwin-x86 install
> make[4]: Entering directory
> `/usr/local/base-3.14.12.1/src/toolsComm/antelope/O.cygwin-x86'
> make[4]: Nothing to be done for `install'.
> make[4]: Leaving directory
> make -C ./flex install
> make[3]: Entering directory `/usr/local/base-3.14.12.1/src/toolsComm/flex'
> `/usr/local/base-3.14.12.1/src/toolsComm/flex/O.cygwin-x86'
> rm -f parse.c y.tab.c
> rm -f parse.h y.tab.h
> ../../../../bin/cygwin-x86/antelope.exe -l -d ../parse.y
> make[4]: *** [parse.c] Error 34
> make[3]: *** [install.cygwin-x86] Error 2
> make[3]: Leaving directory `/usr/local/base-3.14.12.1/src/toolsComm/flex'
> make[2]: *** [flex.install] Error 2
> make[2]: Leaving directory `/usr/local/base-3.14.12.1/src/toolsComm'
> make[1]: *** [toolsComm.install] Error 2
> make[1]: Leaving directory `/usr/local/base-3.14.12.1/src'
> make: *** [src.install] Error 2
> Zhan Zhang, Ph. D.
> 9700 S. Cass Ave.
> Argonne, IL 60439
> Tel : 630-252-0863
- problem with gateway and softIoc running on same server Kevin Tsubota
- Re: problem with gateway and softIoc running on same server Dirk Zimoch
- RE: problem with gateway and softIoc running on same server Kevin Tsubota
- Problem installing EPICS Base 3.14.12.1 on Cygwin/Win XP (32bit) Zhan Zhang
- Re: Problem installing EPICS Base 3.14.12.1 on Cygwin/Win XP (32bit) Janet Anderson
<2011>
Re: problem with gateway and softIoc running on same server Ralph Lange
<2011>
