1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: caGateway crashes / use of *MustSucceed functions
Cc: [email protected]
Date: Thu, 19 May 2011 13:34:35 +0200
Andrew Johnson wrote:
[...], but assert() calls may legally appear in places where the assertion can only fire if there is a real bug in the code.
I agree. That's exactly my point. Assertions should fire on programming errors, but not on run-time problems like unavailable memory.
So calling assert() on the result of epicsEventWait() is OK because that only fails if the event id is invalid which is a programming error. Calling assert on the result of epicsEventCreate() is not OK.
Dirk
caGateway crashes / use of *MustSucceed functions Dirk Zimoch
Re: caGateway crashes / use of *MustSucceed functions Benjamin Franksen
Re: caGateway crashes / use of *MustSucceed functions J. Lewis Muir
Re: caGateway crashes / use of *MustSucceed functions Andrew Johnson
Prev: Re: problem with gateway and softIoc running on same server Ralph Lange
Next: CA beacon routing error S_errno_ECONNREFUSED J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: caGateway crashes / use of *MustSucceed functions Andrew Johnson
Next: Visit of SLAC/ALS control room? emmanuel_mayssat
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
