1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Channel Access not connecting
To: Jeff Hill <[email protected]>
Cc: [email protected]
Date: Wed, 18 May 2011 00:25:15 -0700
Sounds like a hack to keep CA happy and maybe it was for me (In which case thanks so much) but in any case must surely by fixed).  --Steve
On 17 May 2011, at 16:24 PM, Jeff Hill wrote:
>> The IOC's server is not yet impacted by the
>> EPICS_CA_INTF_ADDR_LIST configuration.
> How about the caget client?
The EPICS_CA_INTF_ADDR_LIST is only used to configure  servers.
>Here's netstat -nr output:
Looks ok. Connecting on the same host requires that an interface sees the loopback of its broadcast, but that always seems to work.
So perhaps it _is_ a firewall issue.
BTW: We see the opposite issue here. When caget runs on the same host as the soft IOC we see the message about the same PV name on multiple servers because of the soft interface for virtualized OS  that is typically installed in the new Linux versions (named typically virbr0 in the our systems). I could possibly cause this virbr0 to be left out of the autoconfiguration if I discriminate against the hardware address?
Jeff
______________________________________________________
Jeffrey O. Hill           Email
[email protected]
LANL MS H820              Voice        505 665 1831
Los Alamos NM 87545 USA   FAX          505 665 5107
Message content: TSPA
With sufficient thrust, pigs fly just fine. However, this is
not necessarily a good idea. It is hard to be sure where they
are going to land, and it could be dangerous sitting under them
as they fly overhead. -- RFC 1925
Sent: Tuesday, May 17, 2011 2:55 PM
To: Jeff Hill
Cc: 'Claude Saunders'; 'Mark Rivers'; [email protected]
On 05/17/2011 08:47 AM, Jeff Hill wrote:
oops, yes I said that backwards, its typically broadcasts that are received
by all servers (on the same host), and unicasts that are received by only by
one of multiple servers (on the same host).
I'm running with defaults for the EPICS_CA* and EPICS_CAS* env
variables, but have also played with EPICS_CA_ADDR_LIST,
EPICS_CA_AUTO_ADDR_LIST, and EPICS_CA_INTF_ADDR_LIST with no success.
The IOC's server is not yet impacted by the EPICS_CA_INTF_ADDR_LIST
configuration.
I've been having trouble with one linux machine where my IOC's
appear to be running correctly, dbgf works from iocsh, but caget
from another window on the same machine fails to connect.
Sounds like a routing level issue. The output from "netstat -r" might be
interesting.
Jeff
Kernel IP routing table
Destination     Gateway         Genmask         Flags   MSS Window  irtt Iface
192.168.254.0   0.0.0.0         255.255.255.0   U         0 0          0 eth2
134.79.32.0     0.0.0.0         255.255.252.0   U         0 0          0 eth0
169.254.0.0     0.0.0.0         255.255.0.0     U         0 0          0 eth2
0.0.0.0         134.79.35.1     0.0.0.0         UG        0 0          0 eth0
Mark suggested a firewall issue.   I'm looking into that now.   This
isn't our normal deployment system.   It's for an experimental chamber that's
currently in a different building at SLAC that wanted to run the same EPICS
motor control as they do when their chamber is installed in the hutch.   That
machine is visible from the internet, and I don't administer it, so I'll need
to find the sysadmin for this machine before making any changes.
This system, kernel 2.6.26.3-29.fc9.x86_64, does have a package called system-config-firewall
installed that says the firewall is enabled.   iptables shows:
# /sbin/iptables -L
Chain INPUT (policy ACCEPT)
target     prot opt source               destination
ACCEPT     all  --  anywhere             anywhere            state RELATED,ESTABLISHED
ACCEPT     icmp --  anywhere             anywhere
ACCEPT     tcp  --  anywhere             anywhere            state NEW tcp dpt:ssh
ACCEPT     tcp  --  anywhere             anywhere            state NEW tcp dpt:mysql
REJECT     all  --  anywhere             anywhere            reject-with icmp-host-prohibited
Chain FORWARD (policy ACCEPT)
Chain OUTPUT (policy ACCEPT)
- Bruce
Channel Access not connecting Bruce Hill
Re: Channel Access not connecting Claude Saunders
RE: Channel Access not connecting Mark Rivers
RE: Channel Access not connecting Jeff Hill
Re: Channel Access not connecting Bruce Hill
Prev: RE: Channel Access not connecting Jeff Hill
Next: Re: Channel Access not connecting Bruce Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
