Are you sure that there is not firewall (e.g. iptables) running on that machine?
Sent: Tue 5/17/2011 12:12 AM
To: Techtalk
Subject: Channel Access not connecting
I've been having trouble with one linux machine where my IOC's appear
to be running correctly, dbgf works from iocsh, but caget from another
window on the same machine fails to connect. I suspect it has something
to do with how the multiple interfaces on this machine are configured, but
so far have been unable to find a solution.
# ifconfig
eth0 Link encap:Ethernet HWaddr 00:1E:68:79:5C:4E
inet addr:134.79.32.161 Bcast:134.79.35.255 Mask:255.255.252.0
inet6 addr: fe80::21e:68ff:fe79:5c4e/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:190759 errors:0 dropped:0 overruns:0 frame:0
TX packets:43567 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:18427912 (17.5 MiB) TX bytes:9772031 (9.3 MiB)
Interrupt:19
eth2 Link encap:Ethernet HWaddr 00:1E:68:79:5C:50
inet addr:192.168.254.2 Bcast:192.168.254.255 Mask:255.255.255.0
inet6 addr: fe80::21e:68ff:fe79:5c50/64 Scope:Link
RX packets:1238443 errors:0 dropped:0 overruns:0 frame:0
TX packets:879202 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:80539799 (76.8 MiB) TX bytes:64420869 (61.4 MiB)
Interrupt:20 Base address:0x4000
Gateway is 134.79.35.1
I'm running with defaults for the EPICS_CA* and EPICS_CAS* env variables,
but have also played with EPICS_CA_ADDR_LIST, EPICS_CA_AUTO_ADDR_LIST,
and EPICS_CA_INTF_ADDR_LIST with no success.
See attached files for casr, epicsEnvShow, ifconfig, and netstat output
for more configuration details. We're running base 3.14.9
everywhere, but this
is the only machine showing this problem.
The casr output includes:
UDP Server:
UDP 0.0.0.0:0(): User="", V4.0, 0 Channels, Priority=0
This looks wrong to me, as my working IOC's show a valid UDP addr, but I'm
not sure how to fix this, or even if this is the root problem.
Any suggestions would be appreciated.
- Bruce
P.S. When I run caget, tcpdump shows:
# /usr/sbin/tcpdump -i eth0 -n -nn udp dst portrange 5064-5065
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on eth0, link-type EN10MB (Ethernet), capture size 96 bytes
21:46:55.934345 IP 192.168.254.2.54260 > 134.79.35.255.5065: UDP, length 16
21:46:57.179960 IP 134.79.32.161.43268 > 134.79.35.255.5064: UDP, length 48
21:46:57.211939 IP 134.79.32.161.43268 > 134.79.35.255.5064: UDP, length 48
21:46:57.275932 IP 134.79.32.161.43268 > 134.79.35.255.5064: UDP, length 48
21:46:57.403935 IP 134.79.32.161.43268 > 134.79.35.255.5064: UDP, length 48
Bruce Hill
Member Technical Staff
SLAC National Accelerator Lab
2575 Sand Hill Road M/S 10
Menlo Park, CA 94025
- Channel Access not connecting Bruce Hill
Re: Channel Access not connecting Maren Purves
Re: Channel Access not connecting Claude Saunders
<2011>
<2011>
