Ralph Lange wrote:
Does anyone have experiences/examples of adding support to the EPICS build system for generating Cexp [1] loadable modules (instead of binaries) for
RTEMS and other target archs that can use Cexp?
We would like to add that option - preferably with an easy statement in the Makefile that creates the module in addition or instead of the completely
linked binary - and would like to make new mistakes instead of the old ones....
All hints, warnings, and rule snippets welcome!
~Ralph
[1] http://www.slac.stanford.edu/~strauman/rtems/cexp/
Here's is what I did for Eric Norum's "RTEMS Spy Utility":
Works great. :)
[ernesto@lcls-dev2 rtemsUtilsSup]$ more Makefile
TOP=..
include $(TOP)/configure/CONFIG
# Build as a static library for an linking
# in with an external IOC application:
LIBRARY_IOC_RTEMS += rtemsutils
# Library Source files
rtemsutils_SRCS += spy.cpp
# Link with the asyn and base libraries
rtemsutils_LIBS += $(EPICS_BASE_IOC_LIBS)
# Install .dbd and .db files
DBD += spy.dbd
# Let's build and OBJ file for loading dynamically
PROD_IOC_RTEMS += rtemsUtilsSup
# rtemsUtilsSup.dbd will be created and installed
rtemsUtilsSup_DBD += spy.dbd
DBD += rtemsUtilsSup.dbd
# rtemsUtilsSup_registerRecordDeviceDriver.cpp derives from
# rtemsUtilsSup.dbd
rtemsUtilsSup_SRCS += rtemsUtilsSup_registerRecordDeviceDriver.cpp
# Compile in the RTEMS Spy utility based on the
# RTEMS Capture Engine
rtemsUtilsSup_SRCS += spy.cpp
# Finally link to the rtemsCom
rtemsUtilsSup_LIBS += rtemsCom
include $(TOP)/configure/RULES
- Generating loadable modules for Cexp Ralph Lange
Re: Generating loadable modules for Cexp Michael Davidsaver
Re: EPICS and Octave Kasemir, Kay
<2011>
CMLOG Execution and configuration problem Ritesh Sugandhi
<2011>
