FYI
We've been running the 64 bit version of gateway 2.0.3.0 since Sept
2009,
compiled against base 3.14.11. As I recall, we had some issues early
on,
but I don't recall them being related to 32 vs 64 bit. It's been
running reliably
since then.
Current IOC count through the gateway machine is over 380, probably
closer
to 400, and our ulimit stack size is the default 10240.
- Bruce
On 04/26/2011 08:19 AM, Andrew Johnson wrote:
On Tuesday 26 April 2011 08:06:52 Martin L. Smith wrote:
If your gateways are running under Linux my understanding is that you may
want to increase the stack size limit. I have a comment in my starter
file:
# Limit stacksize for Linux to increase number of threads
# 1024 is 204 threads (default)
# 4096 is 512 threads
ulimit -s 4096
As you can see I use 4096 although I'm not sure that this will help
especially if you are not running on Linux.
I want to add a little more information about what this actually does for
future reference: Like most operating systems Linux has to reserve a fixed
amount of virtual memory space for the program stack for each independent
thread that gets started. You can't move or extend a stack after the thread
has started as each thread's stack is separated by the reserved distance from
the next thread.
It depends on your particular distribution but that distance often defaults to
around 10240KB=10MB. If you're running on a 32-bit Intel CPU the OS usually
only allows a process to use half of its virtual memory space, i.e. 2GB.
2GB=2048MB divided by 10MB means that a single process such as the Gateway
can't have more than 204 threads by default. The CA client library starts two
threads for each IOC it talks to, so that would limit the gateway or
nameserver to connecting with at most about 100 IOCs.
Marty's "ulimit -s 4096" command sets the default stack size to 4096KB=4MB,
thus permitting up to about 512 threads or 256 IOCs. You can find the limit
for a particular machine by running "ulimit -s" under Bash or "limit" under
the C-shell. In practice it should be possible to run the gateway code with a
significantly smaller limit, but I don't know if anyone has tried to find out
how small you can go — I would expect it to still work in 64K, although it
seems unlikely that anyone would need a single gateway able to connect to
32768 IOCs.
An alternative is to run the gateway on a 64-bit machine where the available
virtual memory space is much larger, but I don't know whether the gateway code
is 64-bit safe — has anyone tried that?
- Andrew
Bruce Hill
Member Technical Staff
SLAC National Accelerator Lab
2575 Sand Hill Road M/S 10
Menlo Park, CA 94025
- gateway aborted by SIGBUS peter.leicester
- Re: gateway aborted by SIGBUS Martin L. Smith
- Re: gateway aborted by SIGBUS Andrew Johnson
[Fwd: Re: Large number of sequencers running per soft IOC under Linux: Kernel becomes unresponsive] Maren Purves
Re: Handle leak in Channel Access Server V4.13 (current EPICS base) - WinXP Carsten Winkler
<2011>
RE: gateway aborted by SIGBUS Jeff Hill
<2011>
ANJ, 18 Nov 2013 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
