1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: gateway aborted by SIGBUS
To: [email protected]
Date: Tue, 26 Apr 2011 10:19:09 -0500
On Tuesday 26 April 2011 08:06:52 Martin L. Smith wrote:
> If your gateways are running under Linux my understanding is that you may
>  want to increase the stack size limit. I have a comment in my starter
>  file:
> # Limit stacksize for Linux to increase number of threads
> # 1024 is 204 threads (default)
> #  4096 is 512 threads
> ulimit -s 4096
> As you can see I use 4096 although I'm not sure that this will help
>  especially if you are not running on Linux.
I want to add a little more information about what this actually does for
future reference: Like most operating systems Linux has to reserve a fixed
amount of virtual memory space for the program stack for each independent
thread that gets started.  You can't move or extend a stack after the thread
has started as each thread's stack is separated by the reserved distance from
the next thread.
It depends on your particular distribution but that distance often defaults to
around 10240KB=10MB.  If you're running on a 32-bit Intel CPU the OS usually
only allows a process to use half of its virtual memory space, i.e. 2GB.
2GB=2048MB divided by 10MB means that a single process such as the Gateway
can't have more than 204 threads by default.  The CA client library starts two
threads for each IOC it talks to, so that would limit the gateway or
nameserver to connecting with at most about 100 IOCs.
Marty's "ulimit -s 4096" command sets the default stack size to 4096KB=4MB,
thus permitting up to about 512 threads or 256 IOCs.  You can find the limit
for a particular machine by running "ulimit -s" under Bash or "limit" under
the C-shell.  In practice it should be possible to run the gateway code with a
significantly smaller limit, but I don't know if anyone has tried to find out
how small you can go — I would expect it to still work in 64K, although it
seems unlikely that anyone would need a single gateway able to connect to
32768 IOCs.
An alternative is to run the gateway on a 64-bit machine where the available
virtual memory space is much larger, but I don't know whether the gateway code
is 64-bit safe — has anyone tried that?
- Andrew
An error is only a mistake if you don't learn from it.
When you learn something from it, it becomes a lesson.
Re: gateway aborted by SIGBUS Bruce Hill
gateway aborted by SIGBUS peter.leicester
Re: gateway aborted by SIGBUS Martin L. Smith
Prev: Re: gateway aborted by SIGBUS Martin L. Smith
Next: RE: gateway aborted by SIGBUS Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: gateway aborted by SIGBUS Bruce Hill
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
