1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: VMIC VMIVME 4105 register cannot be modified?
To: [email protected]
Cc: 马晓媛 <[email protected]>
Date: Mon, 25 Apr 2011 14:19:45 -0500
On Sunday 24 April 2011 22:26:44 马晓媛 wrote:
> I worked with VMIVME 4105, but now it comes across some problem that I
>  cannot handle.VMIVME 4105 is a 8channel 12bits multiplying DAC board. I
>  modified the driver of VMIVME 4100 to 4105's driver. VMIVME 4100 is a
>  16channel 12bit DAC board. They are alike.
> Now I can configure the CSR, BUT, I cannot write D15 to "0" to write data
>  to DAC channels. Why? I need your help. Thank you very much!^_^
When you say you cannot do that, what actually happens when you try writing a
16-bit value with D15=0 to one of the DAC OUT registers?
Please copy & paste and command you're using and the error messages you see
directly from the system console, and include more information rather than
less if you're not sure what might be relevant.  You should also explain what
CPU board, OS version and driver you are using.  We can't help you very much
without knowing more about what you are doing.
- Andrew
An error is only a mistake if you don't learn from it.
When you learn something from it, it becomes a lesson.
VMIC VMIVME 4105 register cannot be modified? 马晓媛
Prev: Re: Handling of String Array in CaChannel library Matt Newville
Next: Re: PV not found 闫芬
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: VMIC VMIVME 4105 register cannot be modified? 马晓媛
Next: Re: Re: VMIC VMIVME 4105 register cannot be modified? 马晓媛
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
