1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: PV not found
To: [email protected]
Date: Mon, 25 Apr 2011 15:16:40 +0800 (CST)
Hello,
I'm having problems with inistalling EPICS on Ubuntu Linux. I've downloaded EPICS Base R3.14.10 and update GNU make to 3.8.1. I've not installed the GNU readLine library, so I have commentted out COMMANDLINE_LIBRARY=READLINE in configure/os/CONFIG_SITE.Common.linux-x86.
I've set the environment variables in .bashrc:
export EPICS_HOST=linux-x86
export EPICS_HOST_ARCH=linux-x86
export EPICS_BASE=/usr/local/epics/base
export EPICS_EXTENSIONS=/usr/local/epics/extensions
export PATH=$PATH:$EPICS_BASE/bin/$EPICS_HOST_ARCH
base compile successfully!
Then I've created an example application in the "iocapps" directory:
cd /usr/local/epics
mkdir iocapps
cd iocapps/
/usr/local/epics/base/bin/linux-x86/makeBaseApp.pl -t example dcct
/usr/local/epics/base/bin/linux-x86/makeBaseApp.pl -i -t example dcct
make
cd iocBoot/
cd iocdcct/
../../bin/linux-x86/dcct st.cmd
#!../../bin/linux-x86/dcct
## You may have to change dcct to something else
## everywhere it appears in this file
< envPaths
epicsEnvSet("ARCH","linux-x86")
epicsEnvSet("IOC","iocdcct")
epicsEnvSet("TOP","/usr/local/epics/iocapps")
epicsEnvSet("EPICS_BASE","/usr/local/epics/base")
cd /usr/local/epics/iocapps
dbLoadDatabase "dbd/dcct.dbd"
dcct_registerRecordDeviceDriver pdbbase
## Load record instances
dbLoadTemplate "db/userHost.substitutions"
dbLoadRecords "db/dbSubExample.db", "user=xyHost"
## Set this to see messages from mySub
#var mySubDebug 1
## Run this to trace the stages of iocInit
#traceIocInit
cd /usr/local/epics/iocapps/iocBoot/iocdcct
iocInit
Starting iocInit
## EPICS R3.14.10 $R3-14-10$ $2008/10/27 19:39:04$
## EPICS Base built Apr 20 2011
## Start any sequence programs
#seq sncExample, "user=xyHost"
epics> dbl
xyHost:aiExample
xyHost:aiExample1
xyHost:aiExample2
xyHost:aiExample3
xyHost:aSubExample
xyHost:calcExample
xyHost:calcExample1
xyHost:calcExample2
xyHost:calcExample3
xyHost:compressExample
xyHost:subExample
xyHost:xxxExample
epics> dbpr xyHost:aiExample2
ASG:                DESC: Analog input No. 2                DISA: 0
DISP: 0             DISV: 1             NAME: xyHost:aiExample2
RVAL: 0             SEVR: MAJOR         STAT: LOLO          SVAL: 0
TPRO: 0             VAL: 2
epics> dbgf xyHost:aiExample2
DBR_DOUBLE:  9
I open another terminal on the same computer
xy@linux:/usr/local/epics/base/bin/linux-x86> caget xyHost:aiExample2
Channel connect timed out: 'xyHost:aiExample2' not found.
xy@linux:/usr/local/epics/base/bin/linux-x86> camonitor xyHost:aiExample2
xyHost:aiExample2              *** Not connected (PV not found)
I do not know why(PV not found)?Any idea what could be wrong, and how to solve it?
Thanks
Horald
体验网易邮箱2G超大附件,轻松发优质大电影、大照片,提速3倍!
Re: PV not found Shen, Guobao
Re: PV not found 闫芬
Prev: VMIC VMIVME 4105 register cannot be modified? 马晓媛
Next: Re: PV not found Shen, Guobao
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Re: VMIC VMIVME 4105 register cannot be modified? 马晓媛
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
