1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: seq-2-0-13-rc2
To: <[email protected]>
Date: Fri, 22 Apr 2011 01:28:52 +0200
Am Donnerstag, 21. April 2011, um 20:44:56 schrieb J. Lewis Muir:
> On 4/20/11 11:21 AM, Benjamin Franksen wrote:
> > This is a second release candidate for seq-2.0.13. I followed Andrew's
> > suggestions and moved the error detection for assign to 64 bit long from
> > snc to the C compiler (via #if ... #error...). This version should now
> > complain if and only if the program contains an assign clause for a long
> > or unsigned long *and* the program is compiled for an architecture where
> > a long is larger than 4 bytes.
> Hi, Ben.
> Now the build fails trying to build tooLong.st.  The build log
> is at
> <https://www.imca.aps.anl.gov/~jlmuir/tmp/seq-2.0.13-rc2-build.txt>.
> If I remove "PROD += tooLong" from test/validate/Makefile, the
> build completes successfully.  The build log for this is at
> <https://www.imca.aps.anl.gov/~jlmuir/tmp/seq-2.0.13-rc2-build-r1.txt>.
> The host was running RHEL 5.6 and the GCC version was "4.1.2
> 20080704 (Red Hat 4.1.2-50)".
I am sorry, I forgot to remove (or rather disable i.e. comment out) the
tooLong test. Compilation is supposed to fail if you assign a long or unsigned
long variable to a PV on 64 bit target archs (e.g. for _HOST target if you
compile on a 64 bit linux). Will fix this in 2.0.13.
Besides this one, no (serious) issues have come up so far for 2.0.13-rc2, so
hopefully I can release 2.0.13 next week. Hope you all find lots of easter eggs
in the meantime... (none in 2.0.13, sorry, maybe you'll have more luck with
the upcoming 2.1.0 ;-)
Cheers
Ben
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführer: Prof. Dr. Anke Rita Kaysser-Pyzalla, Prof. Dr. Dr. h.c. Wolfgang Eberhardt, Dr. Ulrich Breuer
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
New sequencer bugfix release candidate Benjamin Franksen
seq-2-0-13-rc2 Benjamin Franksen
Re: seq-2-0-13-rc2 J. Lewis Muir
Prev: Re: About ASG usage Andrew Johnson
Next: Re: About ASG usage jun-ichi.odagiri
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: seq-2-0-13-rc2 J. Lewis Muir
Next: Support for Highland V344/V346 waveform generators? Ralph Lange
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
