> It seems for DBF_STRING array there is certain
> overhead, 16 bytes, when reading from CA client.
> In your case, setting EPICS_CA_MAX_ARRAY_BYTES to
> 2621416 works (but 2621415 didn?t work).
As I recall, the size of the ca protocol header (16 bytes) _is_ implicitly
added to the users request in EPICS_CA_MAX_ARRAY_BYTES so that such
anomalies don?t occur, but perhaps I have neglected to add implicitly
additional amounts for the larger (by 8 bytes) protocol header emitted when
the request size is more than 0xffff bytes. Admittedly, this doesn?t yet
fully explain the 15/16 transition of the issue that you are observing.
In any case I have created a bug entry so that this issue can be tracked,
and fixed.
https://bugs.launchpad.net/epics-base/+bug/768670
Jeff
______________________________________________________
Jeffrey O. Hill Email [email protected]
LANL MS H820 Voice 505 665 1831
Los Alamos NM 87545 USA FAX 505 665 5107
Message content: TSPA
With sufficient thrust, pigs fly just fine. However, this is
not necessarily a good idea. It is hard to be sure where they
are going to land, and it could be dangerous sitting under them
as they fly overhead. -- RFC 1925
> -----Original Message-----
> From: [email protected] [mailto:[email protected]]
> On Behalf Of Wang Xiaoqiang
> Sent: Thursday, April 21, 2011 2:23 PM
> To: Ritesh Sugandhi
> Cc: [email protected]
> Subject: RE: Handling of String Array in CaChannel library
> Hi,
> It seems for DBF_STRING array there is certain overhead, 16 bytes, when
> reading from CA client. In your case, setting EPICS_CA_MAX_ARRAY_BYTES to
> 2621416 works. I verified with caget from epics base
> [-bash SLSBASE=/work]$ export EPICS_CA_MAX_ARRAY_BYTES=2621415
> [-bash SLSBASE=/work]$ /usr/local/epics/base/bin/SL5-x86/caget -d
> DBR_STRING swave
> Read operation timed out: some PV data was not read.
> swave
> *** CA error The requested data transfer is greater than available
> memory or EPICS_CA_MAX_ARRAY_BYTES
> [-bash SLSBASE=/work]$ export EPICS_CA_MAX_ARRAY_BYTES=2621416
> [-bash SLSBASE=/work]$ /usr/local/epics/base/bin/SL5-x86/caget -#10 -d
> DBR_STRING swave
> swave
> Data type: DBR_STRING (native: DBF_STRING)
> Element count: 10
> Value:
> The reason behind should be answered by experts then.
> Best,
> Xiaoqiang
> From: Ritesh Sugandhi [mailto:[email protected]]
> Sent: Thu 4/21/2011 5:25 PM
> To: Wang Xiaoqiang
> Subject: Handling of String Array in CaChannel library
> Dear Sir,
> thanks for sharing the code, using your code I have mange to read and
> write
> array a simple array.
> I am able to successfully enhance the code to read and write a double
> array
> of size 64k ( 65535) elements. in this case I am using
> EPICS_CA_MAX_ARRAY_BYTES configuration was 524280 ( i.e. 65535 * 8 bytes
> for
> double). this works successfully
> I have declared a string Array of 65535 elements and this time I have
> setted
> EPICS_CA_MAX_ARRAY_BYTES to 2621400 (i.e. 40*65535 considering size of 40
> bytes for string) at server and client side. running with this gives error
> $ python2.6 ca-channel-v1.6-demo-waveform-string-64k.py
> ('total values are', 65535)
> The requested data transfer is greater than available memory or
> but when I set EPICS_CA_MAX_ARRAY_BYTES to greater then 26214*20 at client
> side.* I get the correct data at client side.
> code is
> from CaChannel import *
> from random import *
> def main():
> try:
> channel = CaChannel('Py:string64k')
> channel.searchw()
> newval=[]
> for i in range(65535):
> newval.append("ABCDEFGHIJKLMNOPQRSTUVWXYZ0123456789-$#")
> channel.putw(newval)
> print('total values are',channel.element_count())
> print(channel.getw())
> del channel
> except CaChannelException, status:
> print ca.message(status)
> main()
> record is
> record(waveform, "Py:string64k")
> field(DESC, "string array")
> field(NELM, "65535")
> field(FTVL, "STRING")
> On Wed, Apr 20, 2011 at 4:21 PM, Wang Xiaoqiang
> <[email protected]>wrote:
> > Hi,
> > Load this into your IOC:
> > record(waveform, "cawave")
> > field(DESC, "numeric array")
> > field(NELM, "20")
> > field(FTVL, "DOUBLE")
> > >>> import CaChannel
> > >>> pv=CaChannel.CaChannel('cawave')
> > >>> pv.searchw()
> > >>> pv.getw()
> > [0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0,
> 0.0,
> > 0.0, 0.0, 0.0, 0.0, 0.0]
> > >>> pv.putw(range(12))
> > >>> pv.getw()
> > [0.0, 1.0, 2.0, 3.0, 4.0, 5.0, 6.0, 7.0, 8.0, 9.0, 10.0, 11.0, 0.0, 0.0,
> > 0.0, 0.0, 0.0, 0.0, 0.0, 0.0]
> > Xiaoqiang
> > *From:* [email protected] [mailto:
> > [email protected]] *On Behalf Of *Ritesh Sugandhi
> > *Sent:* Wednesday, April 20, 2011 3:48 PM
> > *To:* [email protected]
> > *Subject:* Handling of Array in CaChannel library
> > Dear Sir,
> > Could I get an example of how to handle sub array and waveforms records
> in
> > CaChannel-v1.6 library code.
> > Best regards,
> > ritesh Sugandhi
- Re: Handling of String Array in CaChannel library Matt Newville
- Handling of String Array in CaChannel library Ritesh Sugandhi
- RE: Handling of String Array in CaChannel library Wang Xiaoqiang
RE: PyEpics and Python threads Jeff Hill
Re: About ASG usage Andrew Johnson
<2011>
<2011>
