It seems for DBF_STRING array there is certain overhead, 16 bytes, when reading from CA client. In your case, setting EPICS_CA_MAX_ARRAY_BYTES to 2621416 works. I verified with caget from epics base
[-bash SLSBASE=/work]$ export EPICS_CA_MAX_ARRAY_BYTES=2621415
[-bash SLSBASE=/work]$ /usr/local/epics/base/bin/SL5-x86/caget -d DBR_STRING swave
Read operation timed out: some PV data was not read.
swave
*** CA error The requested data transfer is greater than available memory or EPICS_CA_MAX_ARRAY_BYTES
[-bash SLSBASE=/work]$ export EPICS_CA_MAX_ARRAY_BYTES=2621416
[-bash SLSBASE=/work]$ /usr/local/epics/base/bin/SL5-x86/caget -#10 -d DBR_STRING swave
swave
Data type: DBR_STRING (native: DBF_STRING)
Element count: 10
Value:
The reason behind should be answered by experts then.
Best,
Xiaoqiang
-----Original Message-----
Sent: Thu 4/21/2011 5:25 PM
To: Wang Xiaoqiang
Cc: [email protected]
Subject: Handling of String Array in CaChannel library
Dear Sir,
thanks for sharing the code, using your code I have mange to read and write
array a simple array.
I am able to successfully enhance the code to read and write a double array
of size 64k ( 65535) elements. in this case I am using
EPICS_CA_MAX_ARRAY_BYTES configuration was 524280 ( i.e. 65535 * 8 bytes for
double). this works successfully
I have declared a string Array of 65535 elements and this time I have setted
EPICS_CA_MAX_ARRAY_BYTES to 2621400 (i.e. 40*65535 considering size of 40
bytes for string) at server and client side. running with this gives error
$ python2.6 ca-channel-v1.6-demo-waveform-string-64k.py
('total values are', 65535)
but when I set EPICS_CA_MAX_ARRAY_BYTES to greater then 26214*20 at client
side.* I get the correct data at client side.
code is
from CaChannel import *
from random import *
def main():
try:
channel = CaChannel('Py:string64k')
channel.searchw()
newval=[]
for i in range(65535):
newval.append("ABCDEFGHIJKLMNOPQRSTUVWXYZ0123456789-$#")
channel.putw(newval)
print('total values are',channel.element_count())
print(channel.getw())
del channel
except CaChannelException, status:
print ca.message(status)
main()
record is
record(waveform, "Py:string64k")
field(DESC, "string array")
field(NELM, "65535")
field(FTVL, "STRING")
On Wed, Apr 20, 2011 at 4:21 PM, Wang Xiaoqiang <[email protected]>wrote:
> Hi,
> Load this into your IOC:
> record(waveform, "cawave")
> field(DESC, "numeric array")
> field(NELM, "20")
> field(FTVL, "DOUBLE")
> >>> import CaChannel
> >>> pv=CaChannel.CaChannel('cawave')
> >>> pv.searchw()
> >>> pv.getw()
> [0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0,
> 0.0, 0.0, 0.0, 0.0, 0.0]
> >>> pv.putw(range(12))
> >>> pv.getw()
> [0.0, 1.0, 2.0, 3.0, 4.0, 5.0, 6.0, 7.0, 8.0, 9.0, 10.0, 11.0, 0.0, 0.0,
> 0.0, 0.0, 0.0, 0.0, 0.0, 0.0]
> Xiaoqiang
> *From:* [email protected] [mailto:
> [email protected]] *On Behalf Of *Ritesh Sugandhi
> *Sent:* Wednesday, April 20, 2011 3:48 PM
> *To:* [email protected]
> *Subject:* Handling of Array in CaChannel library
> Dear Sir,
> Could I get an example of how to handle sub array and waveforms records in
> CaChannel-v1.6 library code.
> Best regards,
> ritesh Sugandhi
- RE: Handling of String Array in CaChannel library Jeff Hill
- Handling of String Array in CaChannel library Ritesh Sugandhi
Re: PyEpics and Python threads Matt Newville
Re: PyEpics and Python threads Andrew Johnson
<2011>
<2011>
