> From: Mark Rivers [mailto:
[email protected]]
> Sent: 21 April 2011 12:03
> To: Jim Chen; Andrew Johnson;
[email protected]
> Cc: Eric Norum
> Subject: RE: shell command arguments limitation?
> Hi Jim,
> I think the vxWorks shell is limited to 10 arguments to function calls.
> However, it should work to run iocsh under vWorks, and then you won't
> have the limit.
> Try adding a call to iocsh before your call to the 14 argument command.
> Mark
> ________________________________
> From:
[email protected] on behalf of Jim Chen
> Sent: Thu 4/21/2011 5:39 AM
> To: 'Andrew Johnson';
[email protected]
> Cc: 'Eric Norum'
> Thanks for all the comments.
> I have a configuration which takes 14 arguments to the shell command
> and
> here is the start up printouts:
> # For VME/VxWorks
> IPAC3 = ipacAddHy8002("3,2")
> new symbol "IPAC3" added to symbol table.
> IPAC3 = 0x1ed56080: value = 0 = 0x0
> #int Hy8417AsynInit(char *portName, int vmeSlotNum, int ipSlotNum, int
> vectorNum,
> # int samples, int average, int
> mode,
> int offset, int clockRate,
> # int extClock, int fastADC, int range, int ChannelNo,
> int
> ChannelBit)
> # Settings are:
> # vmeslot=0, ipslot=5, vector=10, samples=1000, average=1,
> mode=1(trigger), offset=0,
> # clockrate=9(1kHz), extclock=0(no), fastADC=0(slow mca & EPID),
> range=0(+/-10V),
> # ChannelNo=16, ChannelBit=16
> Hy8417AsynInit("ADC8417", IPAC3, 1, 10, 1000, 1, 1, 0, 9, 0, 0, 0, 16,
> 16)
> too many arguments to functions.
> Done executing startup script /localhome/local/st.cmd
> It complains about "too many arguments to functions."
> Interestingly, it doesn't complain in my Linux box.
> I remember few years ago we had similar situation with about 18
> arguments in
> a configuration routine, we ended up splitting them into two with the
> first
> one taking 12 and it works fine since.
> The test environment: VxWorks 5.5, processor board MVME5500, EPICS
> 3.14.8.2.
> Any ideas please?
> Jim
> Hytec Electronics Ltd.
> Tel:
+44 (0) 118 975 7770
> Fax:
+44 (0) 118 975 7566
> Web:
www.hytec-electronics.co.uk
> Incorporated in England No 1246940
> VAT NO GB 285 2479 27
> > -----Original Message-----
> > From:
[email protected] [mailto:
tech-talk-
[email protected]] On Behalf Of Andrew Johnson
> > Sent: 20 April 2011 18:18
> > To:
[email protected]
> > Cc: Eric Norum
> > Subject: Re: shell command arguments limitation?
> > On Wednesday 20 April 2011 12:02:31 Eric Norum wrote:
> > > The ioc shell doesn't call its registered functions with individual
> > > arguments so the limit you're describing does not exist. iocsh
> > handler
> > > functions are called with a single argument -- a pointer to an
> array
> > of
> > > argument unions. The only limit that I can see is the amount of
> > memory
> > > available to hold this array.
> > There may be a limit to the length of the command line buffer which
> > would
> > restrict the number of arguments, but that probably depends on the
> > underlying
> > OS and what the EPICS_READLINE setting is.
> > Jim may have been remembering the arguments to the vxWorks taskSpawn()
> > function, which is limited to 10 arguments. I'm not aware of a limit
> > in the
> > vxWorks shell either, but there may be one that I haven't come across
> > yet.
> > - Andrew
> > An error is only a mistake if you don't learn from it.
> > When you learn something from it, it becomes a lesson.
