1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: PyEpics and Python threads
To: "Vigder, Mark" <[email protected]>
Date: Wed, 20 Apr 2011 15:06:33 -0500
Hi Mark,
On Wed, Apr 20, 2011 at 1:04 PM, Vigder, Mark
<[email protected]> wrote:
> I'm working on getting PyEpics and Python threads to work together. I get a
> lot of
> inconsistent behaviour, but the following seems to be somewhat consistent.
> At least
> today it is. I have a motor record, 'L3:m1' and run the following:
> from threading import Thread
> import epics
> import random
> def th(pv, sp):
>     epics.ca.context_create()
>     pv.put(sp, wait=True)
>     epics.ca.context_destroy()
> if __name__ == '__main__':
>         d1=random.randrange(360)
>         m = epics.PV('L3:m1')
>         t1 = Thread(target=th, args=(m, d1))
>         t1.start()
> When executing the 'pv.put' statement, this (almost) always sits for about
> 30 seconds
> doing nothing, and then moves the motor correctly. Why the 30 second delay?
> However, the following program usually (though not always) executes
> correctly
> without the 30 second delay.
> import epics
> import random
> def th(pv, sp):
>         anyPV = epics.PV('L3:scan1')
>         t1.start()
> The only difference is I created some arbitrary unrelated PV before starting
> the thread. I'm still
> trying to understand CA contexts, so I'm not sure those calls are necessary,
> but
> for some things I tried they seemed to be required. Other little changes,
> such as creating the
> PV object inside the thread rather than passing it in to the thread, also
> seem to eliminate the 30 second delay.
> Trying on my PC rather than linux co-hosted with IOC gives about a 10 second
> delay.
> Any help or explanations are well appreciated.
The default timeout for pv.put() in "put-with-wait" mode is 30
seconds, which is probably where that time is coming from.
It appears that the put-with-wait is not announcing completeness
across "contexts" (that is you create a PV in the main thread, then
create a new context in the created thread and do the put-with-wait on
the PV from the original thread).  It's possible thatt the
put-with-wait is not complete enough for dealing with all thread cases
right now.
--Matt Newville
Re: PyEpics and Python threads Andrew Johnson
PyEpics and Python threads Vigder, Mark
Prev: Re: status of Debian/Ubuntu packages/repositories Michael Davidsaver
Next: Re: status of Debian/Ubuntu packages/repositories Bill Lavender
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: PyEpics and Python threads Vigder, Mark
Next: Re: PyEpics and Python threads Andrew Johnson
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
