The ioc shell doesn't call its registered functions with individual arguments so the limit you're describing does not exist. iocsh handler functions are called with a single argument -- a pointer to an array of argument unions. The only limit that I can see is the amount of memory available to hold this array.
On Apr 20, 2011, at 9:53 AM, Hu, Yong wrote:
> I guess the limitation is determined by the C++/C language. As I recalled from some textbooks, 256 Max. arguments in one function call in C++ and 128 in C.
> But I guess nobody writes a function with tens of arguments. I did write a configuration function as ioc shell with 9 arguments which works well.
> Yong
>> -----Original Message-----
>> From: [email protected] [mailto:tech-talk-
>> [email protected]] On Behalf Of Jim Chen
>> Sent: Wednesday, April 20, 2011 12:36 PM
>> To: [email protected]
>> Subject: shell command arguments limitation?
>> Hello,
>> I remember there used to be a limitation for the number of arguments in
>> a single ioc shell command (configuration for example). What exact
>> number is it since R3.14.11 release or is there a one please?
>> Thanks,
>> Jim
>> Hytec Electronics Ltd.
>> Tel: +44 (0) 118 975 7770
>> Fax: +44 (0) 118 975 7566
>> Web: www.hytec-electronics.co.uk
>> Incorporated in England No 1246940
>> VAT NO GB 285 2479 27
Eric Norum
[email protected]
- Re: shell command arguments limitation? Andrew Johnson
- New sequencer bugfix release candidate Benjamin Franksen
- seq-2-0-13-rc2 Benjamin Franksen
- shell command arguments limitation? Jim Chen
- RE: shell command arguments limitation? Hu, Yong
<2011>
<2011>
