Hi Luca,
Is it possible to send a short example of code and the full error
message you're seeing? That would really help diagnose the problem.
It should not be necessary (or even useful) to re-create a PV on
reconnection.
--Matt
On Wed, Apr 20, 2011 at 2:21 AM, Luca Luisa <[email protected]> wrote:
> Hi,
> I tried to types of code:
> 1. in the first one I don't disconnect the PV when the Server disconnects
> and I just wait an automatic reconnection.
> 2. in the second I disconnect the PV, and re-create it again when the server
> connects again.
> In both cases I get the same error.
> Luca
> On 04/19/2011 12:19 AM, Jeff Hill wrote:
>> Hi Matt, Luca,
>> Sorry about the delay responding - I was away on business at the end of
>> last
>> week.
>>>> EPICS server, I get a lot of unknown errors in the terminal
>>>> from where I launch my application, those are:
>>>> TypeError: __on_connect() got an unexpected keyword argument 'count'
>>>> Traceback (most recent call last):
>>>> File "_ctypes/callbacks.c", line 295, in 'calling callback function'
>>>> File "/usr/local/lib/python2.6/dist-packages/epics/ca.py",
>>>> line 420, in _onGetEvent
>>>> args.usr(value=value, **kwds)
>> Despite some similarities, I don’t believe that this particular message
>> originates from the ca client library.
>> Note also that if you do not unsubscribe when the circuit becomes
>> unresponsive then the ca client library will auto-magically re-subscribe
>> on
>> your behalf should the channel need to be reconnected on a fresh TCP
>> circuit.
>> Jeff
>> ______________________________________________________
>> Jeffrey O. Hill Email [email protected]
>> LANL MS H820 Voice 505 665 1831
>> Los Alamos NM 87545 USA FAX 505 665 5107
>> Message content: TSPA
>> With sufficient thrust, pigs fly just fine. However, this is
>> not necessarily a good idea. It is hard to be sure where they
>> are going to land, and it could be dangerous sitting under them
>> as they fly overhead. -- RFC 1925
>>> -----Original Message-----
>>> From: [email protected] [mailto:tech-talk-
>>> [email protected]] On Behalf Of Matt Newville
>>> Sent: Thursday, April 14, 2011 10:07 AM
>>> To: [email protected]; EPICS Tech Talk
>>> Subject: Re: ca.py - Throws error - workaround
>>> Hi Luca,
>>> I hope it's OK with you that I'm sending the message to Tech-Talk,
>>> where there are many people with much better understanding of Channel
>>> Access than I have.
>>> On Thu, Apr 14, 2011 at 1:58 AM, Luca Luisa<[email protected]> wrote:
>>>> Hi,
>>>> I'm working with PyEpics version 3.1.1.
>>>> My QT Python application communicates with many EPICS servers where
>>> hundred
>>>> of PVs are delivered.
>>>> Our application has to deal with any EPICS server
>>>> disconnection/re-connection that can happen during the application run.
>>>> Each PV used by this QT Python application has a callback function
>>> added
>>>> with the module "add_callback()".
>>>> When I noticed an EPICS server disconnection, I clear the callbacks
>>> with the
>>>> method "clear_callbacks()".
>>>> When any EPICS server re-connect again, I try to add again another
>>> callback
>>>> function to the same PV instance previously created, if fails (the
>>>> add_callback returns None) I re-create the PV instance again and try to
>>> add
>>>> the callback function.
>>>> But in the cycle above described used to handle the dynamic connection
>>> to
>>>> EPICS server, I get a lot of unknown errors in the terminal from where
>>> I
>>>> File "/usr/local/lib/python2.6/dist-packages/epics/ca.py", line 420,
>>> in
>>>> _onGetEvent
>>>> Our application is very complex so I cannot send you an example.
>>>> In order to remove this error that full-fills the terminal window, I
>>> had to
>>>> change the "ca.py" source with a try: except: statement.
>>>> The diff is:
>>>> 419,423c419,420
>>>> < try:
>>>> < if hasattr(args.usr, '__call__'):
>>>> < args.usr(value=value, **kwds)
>>>> < except:
>>>> My solution is a pure workaround to make my application working and I
>>> got
>>>> success but I would like to know if this is a known error or my way to
>>>> handle connection/disconnection of a EPICS server is wrong.
>>>> Many thanks
>>>> Ing. Luca Luisa
>>> I'm reluctant to make that change, as it's the only place ca.py can
>>> tell the programmer that there was an error in running the
>>> user-supplied callback and this change silences that message.
>>> This message:
>>> in
>>>> _onGetEvent
>>> says that PV.__on_connect() -- the internally defined connection
>>> callback for a PV -- is being run as a change-in-value callback. I'm
>>> not sure how that's even possible.
>>> with the
>>> I'm not sure this is necessary. Have you tried not doing this?
>>> Obviously, you won't get a callback from a disconnected PV, and will
>>> get a callback upon reconnection, but I would think that's not worse
>>> than explicitly clearing and re-setting callbacks. I can verify that
>>> it does works for me in simple test scripts to not clear "change
>>> value" callbacks and restart the server IOC.
>>> callback
>>> add
>>> For PV.add_callback() to return None, the PV has to be unconnected --
>>> or at least that's the intention. So it's hard to understand what's
>>> happening if you wait for reconnection to add a callback. I do think
>>> it shouldn't be necessary to re-create the PV.
>>> I'm not sure whether this is related to using QT. A minimal example
>>> would be really helpful.
>>> --Matt
- Re: ca.py - Throws error - workaround Matt Newville
- RE: ca.py - Throws error - workaround Jeff Hill
- Re: ca.py - Throws error - workaround Luca Luisa
RE: Handling of Array in CaChannel library Wang Xiaoqiang
gateway aborted by SIGBUS peter.leicester
<2011>
Re: ca.py - Throws error - workaround Geoff Savage
<2011>
