Hi Jeff,
Thanks. I thought the error message reported was a little cryptic
too. The message I see when an array size is larger than
EPCIS_CA_MAX_ARRAY_BYTES looks like this:
>>> import os, epics
>>> print os.getenv('EPICS_CA_MAX_ARRAY_BYTES')
100000
>>> epics.caget('Py:double64k')
Traceback (most recent call last):
File "<stdin>", line 1, in <module>
File "/usr/lib/python2.6/site-packages/epics/__init__.py", line 95, in caget
as_numpy=as_numpy)
File "/usr/lib/python2.6/site-packages/epics/pv.py", line 190, in get
as_numpy=as_numpy)
File "/usr/lib/python2.6/site-packages/epics/ca.py", line 360, in wrapper
return fcn(*args, **kwds)
File "/usr/lib/python2.6/site-packages/epics/ca.py", line 853, in get
PySEVCHK('get', ret)
File "/usr/lib/python2.6/site-packages/epics/ca.py", line 372, in PySEVCHK
raise CASeverityException(func_name, message(status))
epics.ca.CASeverityException: get returned 'The requested data
transfer is greater than available memory or EPICS_CA_MAX_ARRAY_BYTES'
so the message in the python exception does include the text from
ca_message(status), in this case with 'status' being the value
returned from ca_array_get(). For reference:
~>caget Py:double64k
Read operation timed out: some PV data was not read.
Py:double64k*** CA error The requested data transfer is greater than
Also, thanks for clarifying the finite if (currently) very large upper
limit on array sizes!
--Matt Newville
- Re: ca.py - Throws error - workaround Matt Newville
- RE: ca.py - Throws error - workaround Jeff Hill
Re: ioc segfault if - c seq flag is not set or +c? Benjamin Franksen
Re: How to know type of record at client end [Py-epics v3.1.1 interface ] Ritesh Sugandhi
<2011>
Re: ca.py - Throws error - workaround Luca Luisa
<2011>
