Hi Euan,
That should be no problem. Of course then your database becomes
incompatible with "normal" versions of EPICS base so that you need to be
careful when upgrading your EPICS version or exporting your database to
other EPICS users. But since the effect of the modification is limited
to the IOCs, it is compatible with any EPICS version on other IOCs and
any client software.
The maximum number is 32768 because the EVNT field is a DBF_SHORT.
You may also be interested in my code to use strings instead of numbers
for soft events from the codeathlon 2010. Unfortunately it didn't make
it into 3.14.12.
https://code.launchpad.net/~dirk.zimoch/epics-base/named-soft-events/+merge/39472
Best regards,
Dirk
[email protected] wrote:
In the EPICS applications developers guide the following is presented:
17.4.2 Event Scanning
Event scanning is built around the following definitions:
#define MAX_EVENTS 256
typedef struct event_scan_list {
CALLBACK callback;
scan_list scan_list;
} event_scan_list;
static event_scan_list
*pevent_list[NUM_CALLBACK_PRIORITIES][MAX_EVENTS];
Is it possible to increase the MAX_NUMBER definition to enable more event numbers to be used in a linux soft IOC?
cheers,
Euan.
Euan Troup CSIRO Astronomy & Space Science +61 2 9372 4660
[email protected]<mailto:[email protected]>
- Increase event number limit Euan.Troup
Does EPICS Base support multi-thread on vxWorks 6.3? lorna . zhang
New sequencer bugfix release candidate Benjamin Franksen
<2011>
<2011>
