On 4/14/11 10:01 AM, Allison, Stephanie wrote:
> I discovered that even building RTEMS 32 bit sequences (using
> the RTEMS 32bit tool chain) on a linux-x86_64 build is
> problematic as the 64bit-built SNC compiler will, in some
> special cases, convert the .st file to a buggy .c file (in the
> initialization of the state event masks).
I had a similar problem compiling on RHEL 5 (linux-x86_64) for
VxWorks (vxWorks-ppc603, vxWorks-ppc604, and
vxWorks-ppc604_long) using EPICS 3.14.11 (+ Known Problems
patches), SEQ 2.0.12 (as packaged in SynApps 5.5), and the
Tornado 2.0.2 toolchain. I haven't had time to investigate, but
indeed the SNC compiler was generating .c files that the
cross-compiler could not compile. I think the SNC compiler was
generating integer values greater than what could fit in 32 bits
which the cross-compiler choked on.
Lewis
J. Lewis Muir
Software Engineer
IMCA-CAT
- Re: ioc segfault if - c seq flag is not set or +c? Benjamin Franksen
- ioc segfault if - c seq flag is not set or +c? Abadie Lana
- RE: ioc segfault if - c seq flag is not set or +c? Abadie Lana
- RE: ioc segfault if - c seq flag is not set or +c? Allison, Stephanie
Re: ca.py - Throws error - workaround Matt Newville
<2011>
<2011>
