1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Python EPICS interface (pyepics 3.1.1) double waveform record (NLEM = 65535 ) record handling exception
To: [email protected]
Date: Tue, 12 Apr 2011 11:06:52 -0500
Also, is your IOC running EPICS Base version R3.14.12 and if so have you
installed the patch from the item dated 2011-01-13 on the Known Problems page
at http://www.aps.anl.gov/epics/base/R3-14/12-docs/KnownProblems.html
Without the patch an R3.14.12 IOC should be able to transfer up to 65534
elements but not 65535 or larger.
- Andrew
On Tuesday 12 April 2011 10:55:38 Mark Rivers wrote:
> It's actually EPICS_CA_MAX_ARRAY_BYTES, not EPICS_CA_MAX_ARRAY_SIZE.  That
>  must be set on both the IOC machine and the Python client machine.
> Mark
> -----Original Message-----
> From: [email protected] [mailto:[email protected]]
>  On Behalf Of Matt Newville Sent: Tuesday, April 12, 2011 10:52 AM
> To: Ritesh Sugandhi
> Cc: [email protected]
> Hi Ritesh,
> What is EPICS_CA_MAX_ARRAY_SIZE set to?  If left unset, I believe you
> would see exactly this behavior (arrays using up to 16384 bytes would
> work, while larger arrays would fail.
> I haven't tested with python 3.2 on 64-bit linux (yet?), so it's
> possible there are issues, but I'd expect that if short arrays of
> doubles work that longer ones would too.
> --Matt Newville
> On Tue, Apr 12, 2011 at 10:29 AM, Ritesh Sugandhi
> <[email protected]> wrote:
> > Dear sir,
> > My Enviorment is
> > pyepics-3.1.1,
> > python 3.2
> > Linux kernal  2.6.18-194 ; 64 bit
> > Context: Testing pyepics library
> > Problem:
> > I am using supplied database (test/pydebug.db) and I am not able to use
> > the double wave form record of 64k elements. while double wave form
> > record of 2k elements works fine.
> > Any suggestion are welcome.
> > Best regards
> > ---- EPICS shell------------------
> > epics> dbpr Py:double64k 2
> > ACKS: NO_ALARM      ACKT: YES           APST: Always        ASG:
> > BKPT: 00            BUSY: 0             DESC: long double waveform
> > DISA: 0             DISP: 0             DISS: NO_ALARM      DISV: 1
> > DTYP: Soft Channel  EGU:                EVNT: 0             FLNK:CONSTANT
> > 0
> > FTVL: DOUBLE        HOPR: 0             INP:CONSTANT        LCNT: 0
> > LOPR: 0             MPST: Always        NAME: Py:double64k  NELM: 65536
> > NORD: 0             NSEV: NO_ALARM      NSTA: NO_ALARM      PACT: 0
> > PHAS: 0             PINI: NO            PREC: 0             PRIO: LOW
> > PUTF: 0             RARM: 0             RPRO: 0             SCAN: Passive
> > SDIS:CONSTANT       SEVR: INVALID       SIML:CONSTANT       SIMM: NO
> > SIMS: NO_ALARM      SIOL:CONSTANT       STAT: UDF           TIME:
> > <undefined>
> > TPRO: 0             TSE: 0              TSEL:CONSTANT       UDF: 1
> > VAL: (nil)
> > ------------- Python shell -----------------------------
> >>>> pv1=PV('Py:double64k')
> > Traceback (most recent call last):
> >   File "_ctypes/callbacks.c", line 259, in 'calling callback function'
> >   File
> > "/home/ITER/sugandr/Desktop/epics-python/Python-3.2/lib/python3.2/site-pa
> >ckages/epics/ca.py", line 391, in _onGetEvent
> >>>>     value = dbr.cast_args(args).contents
> > ValueError: NULL pointer access
An error is only a mistake if you don't learn from it.
When you learn something from it, it becomes a lesson.
Re: Python EPICS interface (pyepics 3.1.1) double waveform record (NLEM = 65535 ) record handling exception Ritesh Sugandhi
Python EPICS interface (pyepics 3.1.1) double waveform record ( NLEM = 65535 ) record handling exception Ritesh Sugandhi
Re: Python EPICS interface (pyepics 3.1.1) double waveform record ( NLEM = 65535 ) record handling exception Matt Newville
RE: Python EPICS interface (pyepics 3.1.1) double waveform record (NLEM = 65535 ) record handling exception Mark Rivers
Prev: RE: Python EPICS interface (pyepics 3.1.1) double waveform record (NLEM = 65535 ) record handling exception Mark Rivers
Next: RE: How to execute CSS/BOY directly in OPIruntime mode ? Chen, Xihui
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: Python EPICS interface (pyepics 3.1.1) double waveform record (NLEM = 65535 ) record handling exception Ritesh Sugandhi
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
