Dear sir, My Enviorment is ---------------------- pyepics-3.1.1, python 3.2 Linux kernal 2.6.18-194 ; 64 bit Context: Testing pyepics library Problem: I am using supplied database (test/pydebug.db) and I am not able to use the double wave form record of 64k elements. while double wave form record of 2k elements works fine.
Any suggestion are welcome. Best regards ---- EPICS shell------------------ epics> dbpr Py:double64k 2 ACKS: NO_ALARM ACKT: YES APST: Always ASG:
BKPT: 00 BUSY: 0 DESC: long double waveform
DISA: 0 DISP: 0 DISS: NO_ALARM DISV: 1 DTYP: Soft Channel EGU: EVNT: 0 FLNK:CONSTANT 0 FTVL: DOUBLE HOPR: 0 INP:CONSTANT LCNT: 0
LOPR: 0 MPST: Always NAME: Py:double64k NELM: 65536 NORD: 0 NSEV: NO_ALARM NSTA: NO_ALARM PACT: 0 PHAS: 0 PINI: NO PREC: 0 PRIO: LOW
PUTF: 0 RARM: 0 RPRO: 0 SCAN: Passive SDIS:CONSTANT SEVR: INVALID SIML:CONSTANT SIMM: NO SIMS: NO_ALARM SIOL:CONSTANT STAT: UDF TIME: <undefined>
TPRO: 0 TSE: 0 TSEL:CONSTANT UDF: 1 VAL: (nil) ------------- Python shell ----------------------------- >>> pv1=PV('Py:double64k') Traceback (most recent call last):
File "_ctypes/callbacks.c", line 259, in 'calling callback function' File "/home/ITER/sugandr/Desktop/epics-python/Python-3.2/lib/python3.2/site-packages/epics/ca.py", line 391, in _onGetEvent
>>> value = dbr.cast_args(args).contents ValueError: NULL pointer access
ANJ, 18 Nov 2013 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
