Hi Ben,
On Tuesday 05 April 2011 04:06:56 Benjamin Franksen wrote:
> The main problem I see is that 2.0.12 says
> typedef long pvLong;
> and then happily assigns pvLong from and to dbr_long_t. As you say, this is
> not catastrophic in most cases, but I need to check if there are things
> like sizeof(pvLong) used in places where in fact sizeof(dbr_long_t) would
> be correct.
The db_access.h header makes dbr_long_t a typedef for epicsInt32; the pvLong
type should probably match that too, and since SNC 2.0.12 makes long SNL
variables regular C longs I think you should be able to do that to simplify
the task.
- Andrew
An error is only a mistake if you don't learn from it.
When you learn something from it, it becomes a lesson.
- sequencer on 64bit linux Benjamin Franksen
- Re: sequencer on 64bit linux Andrew Johnson
- Re: sequencer on 64bit linux Benjamin Franksen
Re: how to use EPICS driver of MicroResearch PMC-EVR Michael Davidsaver
<2011>
how to use EPICS driver of MicroResearch PMC-EVR 王林
<2011>
