1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: MAXv question
To: EPICS <[email protected]>
Date: Fri, 01 Apr 2011 14:36:52 +0200
Hi all,
Is anyone using the @DPM_ON@ feature of the MAXv motor driver? I would like to modify it.
At the moment this feature allows to use the general purpose bits 0...7 as inputs to monitor the motor power. At the SLS our motor amplifiers support this feature. Thus it might be that it had originally been added by us (David Maden) for the OMS VME58 but I am not sure.
Now for the MAXv I would rather use bits 8...15 because bits 6 and 7 are not available on the backplane, only on the front connector, and we use a backplane transition module to connect our motors.
And I would like to integrate that change into the main software branch. So before breaking anything: Does anyone see a problem with that?
Dirk
RE: MAXv question Mark Rivers
Re: MAXv question Ron Sluiter
Prev: Re: More base 3.14.12 problems on solaris-spac (version 5.8) Dirk Zimoch
Next: RE: MAXv question Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: 3.14.12 Breaks DB file dependency checking Craig.Haskins
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
