1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: how to build c++
To: "yangyong203" <[email protected]>, "EPICS tech-talk" <[email protected]>
Date: Tue, 29 Mar 2011 15:25:38 -0500
On Tuesday 29 March 2011 07:11:57 yangyong203 wrote:
> My error messages as follow:
> /usr/bin/g++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
> -D_XOPEN_SOURCE=500           -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux
> -D_REENTRANT   -O3   -Wall      -m32     -g -fPIC -I. -I../O.Common -I.
> -I.. -I../../../include/os/Linux -I../../../include
> -I/epics0320/base/include/os/Linux -I/epics0320/base/include
> ../dbSubExample.cpp
> In file included from ../dbSubExample.cpp:6:
> /epics0320/base/include/aSubRecord.h:163: error: expected unqualified-id
> before ‘!’ token
Ah, this is a very specific problem with the aSub record, which contains a
field named 'NOT', which becomes a structure data member 'not'.  The word
'not' is a reserved word in C++ (which the compiler has replaced with the
synonym '!' in the above error message) but not in C, thus the dbSubExample.c
file compiles but it doesn't if you rename it and try to use the C++ compiler.
There is a very simple fix though: Insert the following macro definition into
your dbSubExample.cpp file before the #include <aSubRecord.h> line:
	#define not no_t
This will change the name that the C++ compiler sees for that data member into
something that it accepts, and the result should then compile properly.
- Andrew
An error is only a mistake if you don't learn from it.
When you learn something from it, it becomes a lesson.
Re: how to build c++ Dirk Zimoch
Prev: RE: Any upcoming EPICS training Dalesio, Leo
Next: Re: how to build c++ Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: how to build c++ Andrew Johnson
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
