1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: GPIB DCL
To: "Robert Emery" <[email protected]>, <[email protected]>
Date: Fri, 25 Mar 2011 23:52:44 -0500
If you open the asynGPIBSetup.adl screen from asynRecord.adl you can issue a Device Clear.  You can see if that clears the problem.
Does restarting the EPICS IOC fix the problem, or do you have to power-cycle the power supply?
Sent: Fri 3/25/2011 11:36 PM
To: [email protected]
Subject: GPIB DCL
I am using EPICS 3.14.12, ASYN 4.15 to control a Kikusui power supply
via an Agilent E5810.  After I use an ASYN record to send a request to
the power supply with bad syntax, the power supply will not reply to any
further requests until I have cycled the power on the supply.  When I
try to repeat this situation without EPICS, using only the web interface
of the E5810 to send GPIB requests, the power supply will respond to
requests after it has received one with bad syntax.  I do not know how
the E5810 is getting around the problem.  I tried setting the ifc
(interface clear) flag in the vxi11Configure command.  Using the
asynSetTraceMask I can see that the ifc command is issued after sending
a GPIB request with bad syntax, and on the scope I can see the IFC line
go low, but this does not solve the problem.  I wanted to try sending a
dcl (clear device) command.  Is there an easy way to do this with ASYN?
I saw a reference to a command IBDCL in asynGPIB, but I'm not sure how
to access this.
Rob Emery
UW Medical Center
Re: GPIB DCL Robert Emery
Prev: GPIB DCL Robert Emery
Next: Re: GPIB DCL Robert Emery
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
