Hi Andrew,
Today I downloaded qpicsQt 1.1.2, built it, and did some testing.
I still get the error:
"Bug in QCaStringFormatting::formatString(). The QVariant type was not expected"
when I try to display contents of a waveform record in a QCaLabel. Here is my waveform record:
record( waveform, "$(P):WF:ERROR"){
field( DESC, "Error Message:")
field( NELM, "128")
field( FTVL, "CHAR")
The same is also true if I connect a QCaShape object to a bit field in a mbbiDirect record.
On a more positive note, I have just finished developing a “byte monitor” widget, which is similar to its counterpart in EDM.
So, now I have two custom CA aware widgets, which work for me. The other is a “specialized” toggle button.
Zen
