1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: waveform transformation
To: emmanuel mayssat <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Mon, 21 Mar 2011 23:59:13 -0500 (CDT)
Emmanuel,
You can do this with an asub routine, or with SNL code, or, if
the transformation is simple enough, with an aCalcout record
(http://www.aps.anl.gov/bcda/synApps/calc/R2-8/aCalcoutRecord.html)
from the synApps calc module.
Tim
----- Original Message -----
> From: "emmanuel mayssat" <[email protected]>
> To: "EPICS tech-talk" <[email protected]>
> Sent: Monday, March 21, 2011 6:42:00 PM
> Subject: waveform transformation
> Hello,
> I have a waveform.
> I would like to apply a linear transformation to that waveform.
> The simplest case would be
> * calibration of ADC raw values to voltages
> * transformation from voltage to engineering units
> Is there a simple way to do this?
> Ultimately I would like to use a subArray....
> So far the only way I have found to do the above is to this is by
> transforming the waveform in the C code.
> Is it possible to do the same in the IOC database?
> Emmanuel
Tim Mooney ([email protected]) (630)252-5417
Software Services Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
waveform transformation emmanuel_mayssat
Prev: Re: non-normalized X WaveF / Y WaveF display Eric Norum
Next: epicsqt emmanuel_mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: waveform transformation emmanuel_mayssat
Next: non-normalized X WaveF / Y WaveF display emmanuel_mayssat
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
