1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: error 'Library not loaded' for virtual linac
To: Kevin Jordan <[email protected]>
Date: Sun, 20 Mar 2011 17:01:46 -0500
On 3/20/11 9:52 AM, Kevin Jordan wrote:
> HI
> I was trying to run virtual linac and I get the following error:
> Last login: Sun Mar 20 10:44:12 on ttys000
> Kevin-Jordans-iMac:~ kevin$ /Users/kevin/Documents/EPICS/vlinac/startMedm.command ; exit;
> dyld: Library not loaded: /sw/lib/libreadline.5.dylib
>   Referenced from: /Users/kevin/Documents/EPICS/vlinac/lib/darwin-x86/libca.3.14.11.dylib
>   Reason: image not found
>   Referenced from: /Users/kevin/Documents/EPICS/vlinac/bin/darwin-x86/medm
> Trace/BPT trap
> logout
> How do I load this library?
> Thanks,
> Kevin
Hi, Kevin.
It looks like it can't find the readline library.  This is
probably because it's not installed on your computer.  Did you
search the Tech-Talk mailing list?  I think the following thread
addresses your issue:
  http://www.aps.anl.gov/epics/tech-talk/2010/msg01443.php
Andrew or vlinac maintainer: I think a binary package like this
should have readline bundled with it or should be built without
the readline support to eliminate this dependency.
Lewis
J. Lewis Muir
Software Engineer
IMCA-CAT
Re: error 'Library not loaded' for virtual linac Andrew Johnson
error 'Library not loaded' for virtual linac Kevin Jordan
Prev: error 'Library not loaded' for virtual linac Kevin Jordan
Next: some CAJ and JCA questions John Dobbins
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: error 'Library not loaded' for virtual linac Andrew Johnson
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
