Hi Elliott,
On Wednesday 16 March 2011 09:19:29 Rod Nussbaumer wrote:
> We use CANbus extensively to control beam optics power supplies. These
> are controlled mostly from VME CPUs using the Tews vxWorks and more
> recently Tews Linux driver, with EPICS device support from Andrew
> Johnson's package.
The Tews driver and CAN device support are included with my drvIpac module,
but are designed for raw CANbus packets using Basic CAN only; the device
support doesn't speak any higher level protocols such as CANopen, and the
driver can only talk to the Tews Tip810 IP module. I haven't followed
developments in CAN since I wrote it well over 10 years ago, and after reading
your description I would not recommend trying to use this for your new
development.
> > Also, is the ASYN framework the best choice if we have to develop a new
> > driver?
Something based on Asyn would probably be the best starting point for future
work, as it supports connecting to TCP, UDP and serial devices out of the box.
- Andrew
An error is only a mistake if you don't learn from it.
When you learn something from it, it becomes a lesson.
- Re: EPICS and large CAN systems Rolf Keitel
- EPICS and large CAN systems Elliott Wolin
- Re: EPICS and large CAN systems Rod Nussbaumer
Re: How to use asyn with linux-GPIB Feng Laurence
RE: class library header file naming and install conventions Jeff Hill
<2011>
<2011>
