I have a waveform record which retrieves data from 2 channels on a VME card upon the card generating an interrupt. I then process this data into channel 1 and channel 2 via two subArray records. Channel 2 data appears immediately following the channel 1 data in the waveform record and is of the same size.
subArray record 1 has INDX = 0, NELM = size of data (calculated from waveform.NORD/2 via calc record), MALM = 16384
subArray record 2 has INDX = size of data, NELM = size of data, MALM = 16384
The maximum samples that the VME card will generate is 16384 per channel.
When I am at my maximum number of samples, I only see 1 sample in subArray record 2, INDX is truncated to MALM - 1 and NORD is 1. As number of samples is reduced NORD increases. It seems that I am only allowed to store (MALM - INDX) samples rather than MALM.
Should it not be the case that I can store the number of sample allocated in MALM? Otherwise I will be allocating memory which I will never be using, in this case double the amount required in subArray 2 as MALM must equal (INDX + NELM) rather than simply NELM.
Clearly I can get the system operating by setting MALM sufficiently high in subArray 2, but it seems that MALM isn't quite doing what it would be expected to do?
Graham--
Scanned by iCritical.
- Re: 'Feature' of subArray record Tim Mooney
- Re: 'Feature' of subArray record Andrew Johnson
Re: epics on FreeBSD: broadcast problem Andrew Johnson
Re: How to use asyn with linux-GPIB Rod Nussbaumer
<2011>
RE: Message logging survey Elliott Wolin
<2011>
