Ok thanks.
If I find anything within the caSnooper application, I'll submit back as a patch.
Murali
-----Original Message-----
Sent: Monday, March 14, 2011 2:29 PM
To: [email protected]
Cc: Shankar, Murali
Subject: Re: caSnooper latest version
Hi Murali,
On Monday 14 March 2011 15:41:11 Shankar, Murali wrote:
> We are seeing a couple of issues with caSnooper here at SLAC and I am
> trying to get to the bottom of these.
> 1) Some network issues have been reported when using caSnooper with
> EPICS R3-14-8-2x. Using R3-14-10 just for caSnooper in a R3-14-8-2x
> environment seems to be a workaround.
I disagree; there were several changes to the CAS code in between those
releases to fix issues in the CAS. If you've found that using a newer version
of Base solves some problems then there are no changes that could be made in
the caSnooper application code to fix them. EPICS is *designed* so that
different versions will inter-operate properly over the network; you shouldn't
hold back the version of Base that one application like this is built against
just because other parts of your system are using a different Base release
(although that does matter when different pieces of code are going to be
linked together into a single executable such as the support modules in an
IOC).
> 2) These seems to be an issue with the -c (Check validity of top n
> requests) on Linux. We are working around this using a perl script to
> digest caSnooper output and then caget for the validity check.
> Is version caSnooper2_1_2_1 (10 Aug 2007) the latest? If this is being
> actively maintained, would there be a later version elsewhere? Are there
> any patches to caSnooper2_1_2_1 we are missing?
There have been no commits to CVS since the 2-1-2-1 release that I can see
from the cvsweb view at
http://www.aps.anl.gov/cgi-bin/epics/cvsweb/extensions/src/caSnooper/
Since Ken Evans retired we've not had to make changes to caSnooper here at APS
— I suspect SLAC is using it more than APS now. If you guys want to
contribute patches we'd be happy to include them, but other than build issues
on newer OSs I don't think we have the effort to actively work on it any more.
HTH,
- Andrew
An error is only a mistake if you don't learn from it.
When you learn something from it, it becomes a lesson.
- caSnooper latest version Shankar, Murali
- Re: caSnooper latest version Andrew Johnson
class library header file naming and install conventions Jeff Hill
<2011>
<2011>
