1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: PyEpics segmentation faults
Date: Tue, 8 Mar 2011 20:06:04 -0600
Hi All,
Sorry, I intended to respond to the whole list, but responded to Mark alone.
As Mark said, the problem he was seeing was specific to PyEpics 3.0.11
on 64-bit systems, and not related to the patches for 3.14.12. The
problem is fixed in the git repository for pyepics.
--Matt Newville <newville at cars.uchicago.edu> 630-252-0431
On Tue, Mar 8, 2011 at 4:40 PM, Vigder, Mark <[email protected]> wrote:
> Andrew/Jeff
> Thanks for the patch suggestions. Turns out the problem was PyEpics 3.0.11 on 64 bit systems. Matt had already fixed it with the latest version that was in the repository.
> I certainly appreciate the help.
> Mark
> From: Andrew Johnson [[email protected]]
> Sent: March 8, 2011 3:16 PM
> To: [email protected]; Vigder, Mark
> Hi Mark,
> Please try applying the patch from the 3.14.12 Known Problems page dated
> 2011-02-16 to your EPICS Base installation to see if it helps.  This patch has
> been reported to fix a couple of CA client issues at different sites now, and
> if it helps you too I'll make it more prominent on that page.
>  http://www.aps.anl.gov/epics/base/R3-14/12-docs/KnownProblems.html
> - Andrew
> On Tuesday 08 March 2011 13:45:32 Vigder, Mark wrote:
>> I'm running PyEpics 3.0.11, on Ubuntu 10.04.2, Epics 3-14-12, Python 2.6.5,
>> linux-x86_64. A while ago (perhaps with earlier versions of something?)
>> everything seemed to be working fine. I hadn't used it for a while, but now
>> when I fire it up I end up with weird behaviour, e.g.:
>> -I type: Motor('XXX:m1'). Returns error, saying 'XXX:m1' is not a motor.
>> -I type: Motor('XXX:m1') a second time. This one works.
>> -Sometime later, I'll get a 'Segmentation fault'.
>> Anybody seen this kind of behaviour? Any ideas what's going on or where I
>> should start looking for solutions?
>> P.S., I just tried with Python3.1. Same thing.
>> Thanks
>> Mark
>> Mark Vigder
>> Canadian Neutron Beam Centre
> An error is only a mistake if you don't learn from it.
> When you learn something from it, it becomes a lesson.
PyEpics segmentation faults Vigder, Mark
Re: PyEpics segmentation faults Andrew Johnson
RE: PyEpics segmentation faults Vigder, Mark
Prev: RE: Asyn/Modbus Delay Mark Rivers
Next: question about previous value of ai Silver
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: PyEpics segmentation faults Vigder, Mark
Next: RE: PyEpics segmentation faults Jeff Hill
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
