1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: generating fake broadcasts
To: [email protected]
Date: Tue, 8 Mar 2011 11:27:20 -0600
Hi John,
On Tuesday 08 March 2011 10:45:55 John Dobbins wrote:
> A vendor of hardware would like to test the robustness of their network
> stack in an EPICS environment. Does anyone know of an easy way to
> generate fake EPICS channel search broadcasts for this purpose? (So they
> can test their hardware without an actual EPICS system).
It would probably be easiest to write a simple CA client that does searches of
a set of random channel names, and maybe send the vendor a statically-compiled
binary of that program.  Note that the search rate decays over time so you may
want to cancel the oldest searches and re-submit them if you want a sustained
packet rate.
I wrote a simple CAS tool that can monitor and report the current search rate,
or you can try the caSnooper extension program, which is a bit more complex.
> Alternatively, where would I find a description of the contents of the
> channel search request packet?
The CA protocol was documented by CosyLab and is available at
  http://epics.cosylab.com/cosyjava/JCA-Common/Documentation/CAproto.html
You might also find the Channel Access Dissector for Wireshark useful, see
  http://www-linac.kek.jp/cont/epics/wireshark/
HTH,
- Andrew
An error is only a mistake if you don't learn from it.
When you learn something from it, it becomes a lesson.
generating fake broadcasts John Dobbins
Prev: Re: generating fake broadcasts Guy Jennings
Next: PyEpics segmentation faults Vigder, Mark
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
