Those errors are printed by your driver when a client passes a
pasynUser->reason field contains a value that your driver does not
recognize. Is your driver written in C using the native asyn
interfaces, or is it derived from the asynPortDriver C++ base class?
How many pasynUser->reason values does your driver support? How have
you implemented the drvUserCreate function?
-----Original Message-----
[mailto:[email protected]] On Behalf Of
[email protected]
Sent: Thursday, March 03, 2011 5:42 PM
To: EPICS tech-talk
Subject: Re: Strange asyn errors
Another type of errors I get is the following:
2011/03/03 23:37:18.361 TS7000_asynDriver::readFloat64 port TS7000:1
invalid
p_asynUser->reason 10
2011/03/03 23:37:18.363 TS7000:1:1:PrmptLngthLI devAsynFloat64::process
read error
2011/03/03 23:37:18.364 TS7000_asynDriver::readFloat64 port TS7000:1
invalid
p_asynUser->reason 11
2011/03/03 23:37:18.365 TS7000:1:2:PrmptLngthLI devAsynFloat64::process
read error
2011/03/03 23:37:18.367 TS7000_asynDriver::readFloat64 port TS7000:1
invalid
p_asynUser->reason 12
2011/03/03 23:37:18.368 TS7000:1:3:PrmptLngthLI devAsynFloat64::process
read error
2011/03/03 23:37:18.369 TS7000_asynDriver::readFloat64 port TS7000:1
invalid
p_asynUser->reason 13
2011/03/03 23:37:18.370 TS7000:1:4:PrmptLngthLI devAsynFloat64::process
read error
2011/03/03 23:37:18.936 TS7000_asynDriver::readInt32 port TS7000:1
invalid
p_asynUser->reason 26
2011/03/03 23:37:18.937 TS7000:1:2:BI devAsynInt32 process read error
2011/03/03 23:37:18.938 TS7000_asynDriver::readInt32 port TS7000:1
invalid
p_asynUser->reason 27
2011/03/03 23:37:18.939 TS7000:1:3:BI devAsynInt32 process read error
2011/03/03 23:37:18.941 TS7000_asynDriver::readInt32 port TS7000:1
invalid
p_asynUser->reason 28
2011/03/03 23:37:19.562 TS7000:1:4:BI devAsynInt32 process read error
2011/03/03 23:37:19.563 TS7000_asynDriver::readInt32 port TS7000:1
invalid
p_asynUser->reason 29
2011/03/03 23:37:19.564 TS7000:1:5:BI devAsynInt32 process read error
Emmanuel
On 15:37 Thu 03 Mar , [email protected] wrote:
> Hello,
> I have an embedded IOC (ts7370) that runs an asyn driver.
> That ioc is renning a seq sequence for data acquisition.
> The acquisition should go as fast as possible.
> I try to optimize the processing speed.
> but from the asyn driver I get the following errors occasionally.
> What do they mean?
> How to fix them ?
> 2011/03/03 23:37:13.889 TS7000:1:6:BI devAsynInt32 getCallbackValue
error, 4 ring buffer
> overflows
> 2011/03/03 23:37:13.890 TS7000:1:7:BI devAsynInt32 getCallbackValue
> overflows
> 2011/03/03 23:37:13.892 TS7000:1:1:AI devAsynFloat64 getCallbackValue
> overflows
> 2011/03/03 23:37:13.895 TS7000:1:1:PrmptLngthLI devAsynFloat64
getCallbackValue error, 4
> ring buffer overflows
> 2011/03/03 23:37:13.897 TS7000:1:1:PrmptRawAvrgLI devAsynFloat64
> Thanks,
> Emmanuel
Emmanuel
- Strange asyn errors emmanuel_mayssat
- Re: Strange asyn errors emmanuel_mayssat
RE: Strange asyn errors Mark Rivers
Gateway/CAS "bad resource" with CAJ? Kasemir, Kay
<2011>
<2011>
