1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: ca subscriptions, invalid pv
To: "Andrew Johnson" <[email protected]>
Cc: [email protected], [email protected]
Date: Wed, 2 Mar 2011 16:55:54 -0800 (PST)
Hi Andrew,
Thank you for your reply. I found the following in the channel access
reference manual under the ca_create_subscription description:
If at any time after subscribing, read access to the specified process
variable is lost, then the call back will be invoked immediately
indicating that read access was lost via the status argument. When read
access is restored normal event processing will resume starting always
with at least one update indicating the current state of the channel.
Is there a list of all the possible values of the status argument and what
they correspond to?
Thank you,
Patrick
> Hi Patrick,
> On Wednesday 02 March 2011 16:45:19 [email protected] wrote:
>> 1. If a channel is connected or reconnects, and a call to
>> ca_create_subscription succeeds or has previously succeeded, is there
>> anything else that could go wrong on the ioc side that might cause the
>> channel not to be monitored (other than the channel disconnecting)? And
>> if
>> so, is there a way to tell from the client side? Do I have to wait for
>> the
>> event handler to be called before I can trust that everything is
>> working?
> The only thing I can think of would be access security, which can change
> dynamically so a channel you once were able to see is blocked, or vice
> versa.
> Your client code can ask to be notified about such changes using the CA
> API
> routine ca_replace_access_rights_event(), or can ask about its current
> access
> rights for a channel using ca_read_access() and ca_write_access().  I seem
> to
> recall that the initial access rights data for a channel get sent /after/
> the
> main channel connection data (so appear after the connection callback) but
> before the initial value event, but I might be wrong about that.
>> 2. How do you usually deal with setting a pv invalid if the data is
>> being
>> put to it from an external program (ie, not device support) and that
>> program fails? Do you write device support for the ioc hosting the pv,
>> and
>> use it to get the value and a status update from the program? Is there a
>> more preferred method?
> Not quite sure what you're after there, do you want the IOC to be able to
> detect when an external program has disconnected, or are you just asking
> how a
> CA client can make a record go into an alarm state?
> The first one is possible using a subroutine record subroutine to look at
> the
> prec->mlis.count field; if there are *no* CA clients monitoring *any*
> fields
> of that subroutine record the count will be zero.  If course this could be
> a
> somewhat fragile mechanism, but you might be able to make it do what you
> need.
> HTH,
> - Andrew
> An error is only a mistake if you don't learn from it.
> When you learn something from it, it becomes a lesson.
RE: ca subscriptions, invalid pv Jeff Hill
ca subscriptions, invalid pv pthomas
Re: ca subscriptions, invalid pv Andrew Johnson
Prev: RE: ca subscriptions, invalid pv Allison, Stephanie
Next: RE: ca subscriptions, invalid pv Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: ca subscriptions, invalid pv Andrew Johnson
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
