Indeed this is a bug of the library as we never really tested to
configure the channel list via the code itself.
I would suggest you to use the app.config file and define:
<configuration>
<appSettings>
<add key="e#ServerList" value="yourserver:yourport"/>
</appSettings>
</configutation>
we do support the following configuration settings:
<add key="e#GetTimeout" value="5000"/>
<add key="e#ServerList" value="sls-cagw.psi.ch:5062"/>
<add key="e#ConnectTimeout" value="5000"/>
<add key="e#channelSearchInterval" value="100"/>
<add key="e#channelSearchMaxPackageSize" value="300"/>
<add key="e#TCPMaxSendSize" value="4096"/>
Sincerly,
Alain Bertrand
-----Original Message-----
[mailto:[email protected]] On Behalf Of Morozov, Petr
Sent: Monday, February 21, 2011 12:45 PM
To: [email protected]
Subject: Epics C# Library
Hello,
I'd like to use EPICS under windows for our project at DESY (Hamburg,
Germany).
I have downloaded EpicsLibrary.dll version 1.2.0.0 and try to use that
under VB.NET 2008.
Simple example has written and I get the error message "Index was
outside the bounds of the array."
You can see the picture in attachment (how it looks like).
What is wrong?
Best regards,
Petr
Vorname Name Deutsches Elektronen Synchrotron (Abteilung)
phone: +49-40-8998-2866 Notkestr. 85
fax: +49-40-8994-2866 22607 Hamburg
e-mail: [email protected] Germany
- Epics C# Library Morozov, Petr
Re: stream without asynPort Dirk Zimoch
<2011>
ITER CODAC Core System Vs 2.0 released Di Maio Franck
<2011>
