1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: GigE cameras stops
To: "Jeff Hill" <[email protected]>, "Eric Norum" <[email protected]>, "Bruce Hill" <[email protected]>
Cc: "Stoffel, Pavel" <[email protected]>, EPICS Tech Talk <[email protected]>
Date: Thu, 17 Feb 2011 20:46:20 -0600
Hi Jeff,
I believe the signal in question is delivered to all threads, hence the messages coming from CA.  Here is some information I found about the Posix timer functions on the opensourceproject.org.cn Website:
The Linux kernel implements the POSIX timers by means of dynamic timers. Thus, they are similar to the traditional ITIMER_REAL interval timers we described in the previous section. POSIX timers, however, are much more flexible and reliable than traditional interval timers. A couple of significant differences between them are:
*	When a traditional interval timer decays, the kernel always sends a SIGALRM signal to the process that activated the timer. Instead, when a POSIX timer decays, the kernel can send every kind of signal, either to the whole multithreaded application or to a single specified thread. The kernel can also force the execution of a notifier function in a thread of the application, or it can even do nothing (it is up to a User Mode library to handle the event).
*	If a traditional interval timer decays many times but the User Mode process cannot receive the SIGALRM signal (for instance because the signal is blocked or the process is not running), only the first signal is received: all other occurrences of SIGALRM are lost. The same holds for POSIX timers, but the process can invoke the timer_getoverrun( ) system call to get the number of times the timer decayed since the generation of the first signal.
So it sounds like Posix timers can send the signal to just a single thread, but it looks like in this case they are sending it to all threads
<https://carsmail1.cars.aps.anl.gov/exchange/rivers/Drafts/RE:%20GigE%20cameras%20stops.EML/31071535.html>
Sent: Thu 2/17/2011 6:36 PM
To: 'Eric Norum'; 'Bruce Hill'
Cc: 'Stoffel, Pavel'; 'EPICS Tech Talk'
Hi Eric,
> inBufClient::fillCondition
> casDGIntfIO::osdRecv ( char * pBufIn, bufSizeT size, // X aCC 361
>     fillParameter parm, bufSizeT & actualSize, caNetAddr & fromOut )
> Jeff -- Is that SOCK_EWOULDBLOCK actually supposed to be SOCK_EINTR?
Negative, actually this code in src/cas (the portable server) is a single
threaded server implementation (single threaded once used to be required for
portability). That design was very dependent on non-blocking socket calls,
and therefore there was a very important test for EWOULDBLOCK on almost
every sock library call (to find out if the call is returning earlier
because it would block). This code worked correctly when interrupted by a
signal but it didn't make any attempt to suppress diagnostic messages about
such interruptions.
The EINTR errno is returned only when interrupted by a signal.
> There's similar looking code in rsrv/cast_server.c:cast_server(void
> *pParm) that has SOCK_EINTR.
So I was assuming that this was an IOC, and that this is the code that is
running.
> IMHO code that uses signals to get things done is inherently evil.....
Signals are certainly questionable in portable code, and a code that has to
be periodically handling signals would spawn off a private thread for this
purpose? Is the signal in question being delivered to all threads in the
process?
Jeff
______________________________________________________
Jeffrey O. Hill           Email        [email protected]
LANL MS H820              Voice        505 665 1831
Los Alamos NM 87545 USA   FAX          505 665 5107
Message content: TSPA
With sufficient thrust, pigs fly just fine. However, this is
not necessarily a good idea. It is hard to be sure where they
are going to land, and it could be dangerous sitting under them
as they fly overhead. -- RFC 1925
> -----Original Message-----
> From: Eric Norum [mailto:[email protected]]
> Sent: Thursday, February 17, 2011 4:48 PM
> To: Bruce Hill
> Cc: EPICS Tech Talk; Stoffel, Pavel; Jeff Hill; Andrew Johnson
> Subject: Re: GigE cameras stops
> As you mentioned, that error appears when there's a signal handler being
> run while a system call is active.   It appears that this message is
> coming from:
>     int status;
>     osiSocklen_t addrSize;
>     sockaddr addr;
>     SOCKET sockThisTime;
>     if ( parm == fpUseBroadcastInterface ) {
>         sockThisTime = this->bcastRecvSock;
>     else {
>         sockThisTime = this->sock;
>     addrSize = ( osiSocklen_t ) sizeof ( addr );
>     status = recvfrom ( sockThisTime, pBufIn, size, 0,
>                        &addr, &addrSize );
>     if ( status <= 0 ) {
>         if ( status < 0 ) {
>             if ( SOCKERRNO != SOCK_EWOULDBLOCK ) {
>                 char sockErrBuf[64];
>                 epicsSocketConvertErrnoToString ( sockErrBuf, sizeof (
> sockErrBuf ) );
>                 errlogPrintf ( "CAS: UDP recv error was \"%s\"\n",
> sockErrBuf );
>         return casFillNone;
> *pParm) that has
> SOCK_EINTR.
> On Feb 17, 2011, at 3:31 PM, Bruce Hill wrote:
> > We're having a problem with 'CAS: UDP recv errors" that's causing
> > our GigE camera IOC's to stop updating images overnight.
> > We're running EPICS 3.14.9, asyn R4.10.1, and areaDetector R1-2.
> > When the images stop, we get these errors on our console:
> > 17_14:39:08:CAS: UDP recv error (errno=Interrupted system call)
> > 17_14:39:09:CAS: UDP recv error (errno=Interrupted system call)
> > Googling "Interrupted system call" seems to indicated that repeating the
> > system call, in this case, recv_from, may be needed.   It appears that
> the CA
> > code is already doing that.
> > I'm hoping that Jeff or Mark, or anyone, may have already seen this
> problem.
> > We've been working on upgrading to 3.14.11 and newer modules, so if this
> > problem has already been fixed we may just need to refocus our efforts
> on
> > the upgrade.
> > Thanks,
> > - Bruce
> Eric Norum
> [email protected]
RE: GigE cameras stops Mark Rivers
Fwd: Re: GigE cameras stops Bruce Hill
Re: GigE cameras stops Eric Norum
RE: GigE cameras stops Jeff Hill
Prev: RE: GigE cameras stops Jeff Hill
Next: RE: GigE cameras stops Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
