1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: stream without asynPort
To: Rod Nussbaumer <[email protected]>, Mark Rivers <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Thu, 17 Feb 2011 14:51:51 -0800
Attached are EDM equivalents of the MEDM screens for asyn record.  They are a result of adl2edl conversion.
Zen
> -----Original Message-----
> From: [email protected] [mailto:[email protected]]
> On Behalf Of Rod Nussbaumer
> Sent: Thursday, February 17, 2011 2:27 PM
> To: Mark Rivers
> Cc: EPICS tech-talk
> Subject: Re: stream without asynPort
> Mark Rivers wrote:
> >> When these are set to produce verbose console output, it can be
> > difficult to turn them off by
> >> typing. Hooking them to EPICS records like multibit binaries could
> > make it really
> >> convenient.
> > That's already possible.  You just connect an asyn record to that asyn
> > port.  The asyn record has a nice medm screen which lets you turn the
> > mask bits on and off.  Moreover, a single asyn record can be switched
> > between ports (and between asyn "addr" addresses) so you don't
> > necessarily need one asyn record for each port, a single asyn record per
> > IOC would be sufficient.
> > Mark
> Okay, I will have to try that, in the case of setting asynTrace masks.
> However, in the more general case, I think being able to use
> streamDevice's exec functions would still benefit from being able to
> access the attached PV.
> Has anyone done a conversion of the MEDM screens to EDM screens related
> to the asyn record? I've often wanted to play with the asyn record, but
> it always looked like the secret to its use was somewhat embedded in the
> screens, and we only use EDM here. I guess I'll have to see if there is
> a Capfast symbol for the asyn record, too...
> Thanks.
>     ---   rod.
Attachment: asynGPIBSetup.edl
Description: asynGPIBSetup.edl
Attachment: asynOctet.edl
Description: asynOctet.edl
Attachment: asynRecord.edl
Description: asynRecord.edl
Attachment: asynRegister.edl
Description: asynRegister.edl
Attachment: asynSerialPortSetup.edl
Description: asynSerialPortSetup.edl
Attachment: asynSocketSetup.edl
Description: asynSocketSetup.edl
Attachment: ipSNCServer.edl
Description: ipSNCServer.edl
Re: stream without asynPort Rod Nussbaumer
stream without asynPort emmanuel_mayssat
RE: stream without asynPort Mark Rivers
Prev: RE: stream without asynPort Mark Rivers
Next: Re: stream without asynPort Rod Nussbaumer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
