Mark Rivers wrote:
When these are set to produce verbose console output, it can be
difficult to turn them off by
typing. Hooking them to EPICS records like multibit binaries could
make it really
convenient.
That's already possible. You just connect an asyn record to that asyn
port. The asyn record has a nice medm screen which lets you turn the
mask bits on and off. Moreover, a single asyn record can be switched
between ports (and between asyn "addr" addresses) so you don't
necessarily need one asyn record for each port, a single asyn record per
IOC would be sufficient.
Okay, I will have to try that, in the case of setting asynTrace masks.
However, in the more general case, I think being able to use
streamDevice's exec functions would still benefit from being able to
access the attached PV.
Has anyone done a conversion of the MEDM screens to EDM screens related
to the asyn record? I've often wanted to play with the asyn record, but
it always looked like the secret to its use was somewhat embedded in the
screens, and we only use EDM here. I guess I'll have to see if there is
a Capfast symbol for the asyn record, too...
Thanks.
--- rod.
- RE: stream without asynPort Mark Rivers
- RE: stream without asynPort Szalata, Zenon M.
- stream without asynPort emmanuel_mayssat
- Re: stream without asynPort Rod Nussbaumer
Re: EtherIP support for "GuardLogix" PLC ? David Dudley
<2011>
<2011>
ANJ, 18 Nov 2013 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
