1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: stream without asynPort
To: "Rod Nussbaumer" <[email protected]>, "EPICS tech-talk" <[email protected]>
Date: Thu, 17 Feb 2011 15:20:45 -0600
> When these are set to produce verbose console output, it can be
difficult to turn them off by
> typing. Hooking them to EPICS records like multibit binaries could
make it really
> convenient.
That's already possible.  You just connect an asyn record to that asyn
port.  The asyn record has a nice medm screen which lets you turn the
mask bits on and off.  Moreover, a single asyn record can be switched
between ports (and between asyn "addr" addresses) so you don't
necessarily need one asyn record for each port, a single asyn record per
IOC would be sufficient.
-----Original Message-----
[mailto:[email protected]] On Behalf Of Rod Nussbaumer
Sent: Thursday, February 17, 2011 3:17 PM
To: EPICS tech-talk
Subject: Re: stream without asynPort
[email protected] wrote:
> Hello,
> Q: apropos is it possible in stream to pass the value of the PV in
exec lines?
>     ex: exec "dbpr mbboPV<valueOfMbboPV>" ;
This is something I would really like to see (and no, AFAIK it isn't
possible right now). An example of where this would be nice would be in
the setting of asynTrace masks. When these are set to produce verbose
console output, it can be difficult to turn them off by typing. Hooking
them to EPICS records like multibit binaries could make it really
convenient.
Rod Nussbaumer
ISAC Controls, TRIUMF
Vancouver, Canada
Re: stream without asynPort Rod Nussbaumer
stream without asynPort emmanuel_mayssat
Prev: Re: stream without asynPort Rod Nussbaumer
Next: Re: EtherIP support for "GuardLogix" PLC ? David Dudley
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: stream without asynPort Rod Nussbaumer
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
