CROSS_COMPILE_TARGET_ARCHS in base 3.14.11 may be wrong. I set it to
"linux-x86".
As I set it to "linux-386", envPaths is generated in
myapps/iocBoot/iocmyapps by make.
Whatever CROSS_COMPILE_TARGET_ARCHS is set to in base 3.14.8.2, envPaths
will be generated.
I think the difference is in the file RULES.ioc .
The 7.1 section of EPICS Application Developer’s Guide has the
following:
"The envPaths file is automatically generated in the IOC boot directory
and defines several environment variables that are useful later in the
startup script" .
Mi Qingru
SSRF
021-33933238
-----原始邮件-----
Sent: Tuesday, February 15, 2011 11:42 PM
To: [email protected]
Cc: Mi Qingru
Subject: Re: no envPaths in application of base 3.14.11
On Monday 14 February 2011 23:57:52 Mi Qingru wrote:
I built an application with the example template from base 3.14.11.
There isn’t envPaths in iocBoot after ‘make’.
The envPaths file is created in the iocBoot/iocmyapps directory, can you
please confirm whether it is or is not present there?
If you read some documentation that implied it would appear directly in the
iocBoot directory would you please tell us where you read it, as it needs to
be corrected.
No error happened in compiling. Only:
make[2]: Entering directory ‘.../apps-11/iocBoot/iocmyapps’
make[2]: Nothing to be done for ‘install’
make[2]: Leaving directory ‘.../apps-11/iocBoot/iocmyapps’
The Makefile in iocBoot/iocmyapps :
TOP=../..
include $(TOP)/configure/CONFIG
ARCH=linux-x86
TARGETS=envPaths
include $(TOP)/configure/RULES.ioc
The base is built for linux-x86.
If EPICS_HOST_ARCH is linux-x86 that Makefile should result in the envPaths
file being created if it doesn't already exist. There are a number of ways
where misconfiguration of your application could cause problems but I can't
think of any that would cause the build to complete like you show above.
- Andrew
If a man is offered a fact which goes against his instincts, he will
scrutinize it closely, and unless the evidence is overwhelming, he will
refuse to believe it. If, on the other hand, he is offered something
which affords a reason for acting in accordance to his instincts, he
will accept it even on the slightest evidence. -- Bertrand Russell
- Re: no envPaths in application of base 3.14.11 Ralph Lange
- no envPaths in application of base 3.14.11 Mi Qingru
- Re: no envPaths in application of base 3.14.11 Andrew Johnson
Re: Arcturus uCDimm + TFTP David Kline
Re: Arcturus uCDimm + TFTP Eric Norum
<2011>
<2011>
