>> The IOC server binds to all the interfaces it can see; there's actually no way to change that with the current code. >> I wonder whether your problem is actually that the machines do not have the same subnet mask settings, and hence their >> broadcast addresses are different? On Unix systems 'ifconfig -a'
>> will print the broadcast address; you need to make sure that all systems are using the same address.
Yes, the two networks have different subnet masks.
I have 255.255.252.0 on eth0 and 255.255.255.0 on eth1.
I'm no expert on network configuration, does this setup make it a non-starter?
Graham
-----Original Message-----
Sent: 15 February 2011 16:08
To: [email protected]
Cc: Paul Sichta; Cox, Graham (STFC,DL,EID)
Subject: Re: EPICS Config for 2 Ethernet Adapters
On Tuesday 15 February 2011 09:52:37 Paul Sichta wrote:
> Look in the CA Reference Manual for your release of EPICS. I think
> you need to specify EPICS_CAS_INTF_ADDR_LIST .
Actually that variable has no effect on the IOC server, it only applies to the CAS which is not (yet) used by the IOC code.
> On Tue, Feb 15, 2011 at 10:33, <[email protected]> wrote:
> > I now need to take the legacy data from one network and make
> > available on another network via EPICS. I have a Linux PC with 2
> > ethernet adapters, eth0 the legacy control system, eth1 the EPICS
> > control system. The IOC runs on this machine except I cannot see
> > the EPICS PVs via other machines on the eth1 network.
> > I'm guessing that the EPICS IOC is binding to eth0 by default and
> > expecting to serve data to this network?
> > How do I configure EPICS to bind to eth1 rather than to eth0, is
> > this possible?
The IOC server binds to all the interfaces it can see; there's actually no way to change that with the current code. I wonder whether your problem is actually that the machines do not have the same subnet mask settings, and hence their broadcast addresses are different? On Unix systems 'ifconfig -a'
The output from running 'casr 1' from the IOC shell may also give some hints.
- Andrew
If a man is offered a fact which goes against his instincts, he will scrutinize it closely, and unless the evidence is overwhelming, he will refuse to believe it. If, on the other hand, he is offered something which affords a reason for acting in accordance to his instincts, he will accept it even on the slightest evidence. -- Bertrand Russell
Scanned by iCritical.
- Re: EPICS Config for 2 Ethernet Adapters Andrew Johnson
- RE: EPICS Config for 2 Ethernet Adapters Jeff Hill
RE: soft ioc runs into fatal exception (base-3.14.12) Jeff Hill
<2011>
<2011>
