1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: soft ioc runs into fatal exception (base-3.14.12)
To: "'Carsten Winkler'" <[email protected]>, <[email protected]>
Date: Fri, 11 Feb 2011 09:46:19 -0700
Hello Carsten,
I committed, and pushed, a fix to the R3.14 branch at launch-pad. Please
test to see if the relevant changes address your issue.
I created lauchpad bug 717252. The details, including diffs, are in the bug
report.
https://bugs.launchpad.net/epics-base/+bug/717252
Thanks for your detailed bug report,
Jeff
______________________________________________________
Jeffrey O. Hill           Email        [email protected]
LANL MS H820              Voice        505 665 1831
Los Alamos NM 87545 USA   FAX          505 665 5107
Message content: TSPA
With sufficient thrust, pigs fly just fine. However, this is
not necessarily a good idea. It is hard to be sure where they
are going to land, and it could be dangerous sitting under them
as they fly overhead. -- RFC 1925
> -----Original Message-----
> From: [email protected] [mailto:[email protected]]
> On Behalf Of Carsten Winkler
> Sent: Friday, February 11, 2011 1:01 AM
> To: [email protected]
> Subject: soft ioc runs into fatal exception (base-3.14.12)
> Problem:             softIoc.exe runs into fatal exception after caput
> call from local host.
>                               When running the test, there's a 40% chance
> for this exception to occur.
>                               Waiting between starting the softIoc and
> caput, and/or waiting between
> caput calls does not change the behavior.
> Error message:  "softIoc has encountered a problem and needs to close. We
> are sorry for the
> inconvience."
> Error details:      AppName: softioc.exe; AppVer:0.0.0.0; ModName:
> com.dll; ModVer: 3.14.12.0;
> Offset: 0000a613
> System:              EPICS 3.14.12 plus all published patches (8 Feb.
> 2011), no local changes
> (compiled with MVS 2010 professional - without any error)
> Host:                   Windows XP SP3 @ Pentium 4 with 3.2GHz and 3GB RAM
>                                                     AND
>                              Windows XP SP3 @ VMWARE 3.5.0
>                                                     AND
>                               Windows XP SP3 @ VIRTUALBOX 3.2.12
>                                                     AND
>                               Windows XP SP3 @ KVM
> Test setup:         The following configuration files have been used:
>      startDemo.bat:
>                                  set EPICS_CA_ADDR_LIST=localhost
>                                  set EPICS_CA_AUTO_ADDR_LIST=NO
>                                  start DemoIOC.cmd
>                                  caput demoHost:double1 3.141
>                                  caput demoHost:double2 2.718
>                                  caput demoHost:long 12345
>      DemoIOC.cmd:
>                                  softIoc.exe -D dbd\softIoc.dbd -d
> db\demo.db
>      demo.db:
>                                  record(ao, "demoHost:double1")
>                                      field(DESC, "Double output with range
> infos")
>                                      field(EGU, "mm")
>                                      field(HOPR, "10")
>                                      field(LOPR, "0")
>                                      field(HIHI, "8")
>                                      field(HIGH, "6")
>                                      field(LOW, "4")
>                                      field(LOLO, "2")
>                                      field(HHSV, "MAJOR")
>                                      field(HSV, "MINOR")
>                                      field(LSV, "MINOR")
>                                      field(LLSV, "MAJOR")
>                                  record(ao, "demoHost:double2")
>                                      field(DESC, "Double output without
> range infos")
>                                      field(EGU, "nm")
>                                  record(longout, "demoHost:long")
>                                      field(DESC, "Long output without
> range infos")
>                                      field(EGU, "m")
> call stack:
> Com.dll!ellDelete(ELLLIST * pList=0x00a22ed0, ELLNODE * pNode=0x00cf0d08)
> Zeile 82 + 0xb Bytes    C
> Com.dll!epicsParmCleanupWIN32(epicsThreadOSD * pParm=0x00cf0d08)  Zeile
> 246 + 0x10 Bytes    C
> Com.dll!epicsWin32ThreadEntry(void * lpParameter=0x00cf0d08)  Zeile 516 +
> 0x9 Bytes    C
> msvcr100d.dll!_callthreadstartex()  Zeile 314 + 0xf Bytes    C
> msvcr100d.dll!_threadstartex(void * ptd=0x00cf1500)  Zeile 297    C
> kernel32.dll!_BaseThreadStart@8()  + 0x37 Bytes
> exception occurred here:
> void ellDelete (ELLLIST *pList, ELLNODE *pNode)
>      if (pList->node.previous == pNode)
>          pList->node.previous = pNode->previous;
>      else
>          pNode->next->previous = pNode->previous; <== "pNode->next" is a
> NULL pointer in error case!
> (s. memory map)
>      if (pList->node.next == pNode)
>          pList->node.next = pNode->next;
>      else
>          pNode->previous->next = pNode->next;
>      pList->count--;
>      return;
> This function was called from "static void epicsParmCleanupWIN32 (
> win32ThreadParam * pParm )" of
> osdThread.c
> memory maps:
> - pList    0x00a22ed0 {node={...} count=23 }    ELLLIST *
>      - node    {next=0x00a24728 previous=0x00cf0c60 }    ELLNODE
>          - next    0x00a24728 {next=0x00a26340 previous=0x00000000 }
> ELLNODE *
>              - next    0x00a26340 {next=0x00adbd90 previous=0x00a24728 }
> ELLNODE *
> [... 20 thread parameter blocks in this list  without address 0x00cf0d08]
>                     - next    0x00cf0c60 {next=0x00000000
> previous=0x00cf0de0 }    ELLNODE *
>                         - next    0x00000000 {next=??? previous=??? }
> ELLNODE *
>                             next    CXX0030: Fehler: Ausdruck kann nicht
> ausgewertet werden
>                             previous    CXX0030: Fehler: Ausdruck kann
> nicht ausgewertet werden
>          + previous    0x00cf0de0 {next=0x00cf0c60 previous=0x00cf0b40 }
> ELLNODE *
>              + previous    0x00cf0b40 {next=0x00cf0de0 previous=0x00af1ac0
> }    ELLNODE *
>      count    23    int
> - pNode    0x00cf0d08 {next=0x00000000 previous=0x00000000 }    ELLNODE *
>      + next    0x00000000 {next=??? previous=??? }    ELLNODE *
>          next    CXX0030: Fehler: Ausdruck kann nicht ausgewertet werden
>          previous    CXX0030: Fehler: Ausdruck kann nicht ausgewertet
> werden
>      + previous    0x00000000 {next=??? previous=??? }    ELLNODE *
> werden
> 0x00CF0C80  00 00 00 00 43 41 53 2d 65 76 65 6e 74 00 fd fd fd fd dd dd dd
> dd dd dd 09 00 0c 00 a1
> 01 0c 02 a0 12  ....CAS-event.ýýýýÝÝÝÝÝÝ....¡... .
> 0x00CF0CA2  cf 00 e8 0c cf 00 00 00 00 00 00 00 00 00 18 00 00 00 01 00 00
> 00 fd 26 00 00 fd fd fd
> fd 00 00 00 00  Ï.è.Ï.................ý&..ýýýý....
> This looks like there is a situation (with a 40% chance), in which the
> thread parameter block of a
> CAS-event task is not added to the thread list when the client connects.
> When the clients
> disconnects and the thread gets shut down, it tries to remove its
> parameter block from the thread
> list by calling ellDelete() with a node that is not in the list.
> ellDelete() behaves fragile and
> crashes the softIoc (by dereferencing a null pointer). This exception
> seems to occur only when caput
> has been called from local host.
> Has anyone seen this behavior?
> Helmholtz-Zentrum Berlin für Materialien und Energie GmbH
> Mitglied der Hermann von Helmholtz-Gemeinschaft Deutscher
> Forschungszentren e.V
> Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv.
> Vorsitzende Dr. Beatrix Vierkorn- Rudolph
> Geschäftsführer: Prof. Dr. Anke Rita Kaysser-Pyzalla, Prof. Dr. Dr. h.c.
> Wolfgang Eberhardt, Dr. Ulrich Breuer
> Sitz Berlin, AG Charlottenburg, 89 HRB 5583
> Postadresse:
> Hahn-Meitner-Platz 1
> D-14109 Berlin
> http://www.helmholtz-berlin.de
Re: soft ioc runs into fatal exception (base-3.14.12) Carsten Winkler
Prev: RE: New widget not available in Boy palette of Control System Studio ZYCHLA Emmanuel
Next: RE: USB4000 David Beauregard
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: soft ioc runs into fatal exception (base-3.14.12) Carsten Winkler
Next: Re: soft ioc runs into fatal exception (base-3.14.12) Carsten Winkler
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
