1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: MEDM build problem
To: "J. Lewis Muir" <[email protected]>
Cc: [email protected]
Date: Mon, 07 Feb 2011 16:08:19 -0600
Hi, Lewis,
Thank you so much. I will try to run it.
Chen
Hi, Lewis,
Thank you for your prompt reply. I found that libXp.so wasn't installed
 yet. Then I updated and installed. Here is the message of building. Do I
 build successfully?
Hi, Chen.
I don't see any errors in the build output you sent, so it looks like it
built OK.  You can confirm by trying to run it.
Lewis
On 2/7/2011 3:47 PM, J. Lewis Muir wrote:
On 2/7/11 3:34 PM, Chen Xue wrote:
/usr/bin/ld: cannot find -lXp
collect2: ld returned 1 exit status
Hi, Chen.
These lines indicate the linker can't find the Xp (Xprint) library.  Do
you have it installed?  On RHEL5, it's at /usr/lib/libXp.so or
/usr/lib64/libXp.so.  On Debian, I don't know, hopefully the same place.
Lewis
MEDM build problem Chen Xue
Re: MEDM build problem J. Lewis Muir
Prev: Re: MEDM build problem ZY (Zhijian Yin)
Next: Re: StreamDevice/ASYN connection to a Telnet port John Dobbins
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: MEDM build problem J. Lewis Muir
Next: Re: MEDM build problem ZY (Zhijian Yin)
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
